Home > Technical (L322) > windscreen wipers park in the middle of windscreen
defenderr
Netherlands
Just bought my first L322 today, hurrah! It's 2002 Vogue V8. Very exciting!
The battery was flat and I had it replaced however there's one strange thing now.
The windscreen wipers park themselves at a 90 degree angle instead of at the bottom of the windscreen.
What can I do to get them to park in the normal position?
Daniel
Post #311272 6th Feb 2015 10:42pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
It could be a faulty park switch in your wiper motor. Similar thing happened to mine and I had to replace the motor. Fairly simple DIY. You also have the wiper relay behind the battery, try to replace it first in case this is broken.
http://www.fullfatrr.com/forum/topic26519.html Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #311276 6th Feb 2015 11:01pm
I would do a hard battery reset first sir Bow down
Post #311289 7th Feb 2015 12:01am
defenderr
Netherlands
Do you need a diagnostic tool to do a hard battery reset or can it be done without tools (from the menu on the dashboard screen)?
Sorry if this is a naive question!
Daniel
Post #311290 7th Feb 2015 12:04am
No Daniel... Open your bonnet sir, take keys out of car and close door... Go and have a cup of coffee for at least 5mins, i suggest 10mins... Without opening any doors! Go straight to the battery and remove the earth lead (brown wire)...
Soft battery reset = leave battery disconnected for 45mins - 1hr
Hard battery reset = touch + & - wires together for 10secs VERY IMPORTANT! NOT the battery terminals! The vehicle wiring Thumbs Up
Post #311294 7th Feb 2015 12:19am
dnbaker
United States 2004 Range Rover Westminster 4.4 V8 Bonatti Grey
I had the same issue shortly after purchasing my '04 and it ended up being a faulty motor. As previously mentioned - it's an easy DIY. I bought a used motor off ebay and it's still going strong 2 yrs later. 2004 RR Westminster 4.4 V8
Bonatti Grey/Jet
Post #311300 7th Feb 2015 2:33am
defenderr
Netherlands
Thanks for that! I've not tried it yet but will later.
Hope that will work, would be better (and cheaper) than replacing parts.
Daniel
Post #311388 7th Feb 2015 6:51pm
Welshdragon
And don't forget when reconnected battery to re set the steering angle, ie turn left and right locks to clear eas. If it dont work.......burn it!
Post #311407 7th Feb 2015 8:06pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Might be way off, but had that on my E type all 3 wipers parked standing up and turned out to be the mass/ earth contact on the wipermotor, but then again I am not a tech Embarassed
Post #311412 7th Feb 2015 9:08pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
my wiper mechanism slipped on the motor shaft once when they triggered after a huge lump of snow slid down the windscreen - they were doing the same as yours, going past home position and stopping few inches up the screen.
Was a dead easy job to loosen the mechanism, re-zero it then tighten the mechanism back up.
Post #311426 7th Feb 2015 10:09pm
defenderr
Netherlands
Tried a few things but in the end the problem was solved by replacing the wiper motor.
Thanks for all the helpful suggestions!
Daniel
Post #312375 12th Feb 2015 10:52pm
