Home > Technical (L322) > windscreen wipers park in the middle of windscreen
defenderr
Netherlands
Just bought my first L322 today, hurrah! It's 2002 Vogue V8. Very exciting!
The battery was flat and I had it replaced however there's one strange thing now.
The windscreen wipers park themselves at a 90 degree angle instead of at the bottom of the windscreen.
What can I do to get them to park in the normal position?
Daniel
Post #311272 6th Feb 2015 9:42pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
It could be a faulty park switch in your wiper motor. Similar thing happened to mine and I had to replace the motor. Fairly simple DIY. You also have the wiper relay behind the battery, try to replace it first in case this is broken.
http://www.fullfatrr.com/forum/topic26519.html Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #311276 6th Feb 2015 10:01pm
I would do a hard battery reset first sir Bow down
Post #311289 6th Feb 2015 11:01pm
defenderr
Netherlands
Do you need a diagnostic tool to do a hard battery reset or can it be done without tools (from the menu on the dashboard screen)?
Sorry if this is a naive question!
Daniel
Post #311290 6th Feb 2015 11:04pm
No Daniel... Open your bonnet sir, take keys out of car and close door... Go and have a cup of coffee for at least 5mins, i suggest 10mins... Without opening any doors! Go straight to the battery and remove the earth lead (brown wire)...
Soft battery reset = leave battery disconnected for 45mins - 1hr
Hard battery reset = touch + & - wires together for 10secs VERY IMPORTANT! NOT the battery terminals! The vehicle wiring Thumbs Up
Post #311294 6th Feb 2015 11:19pm
dnbaker
United States 2004 Range Rover Westminster 4.4 V8 Bonatti Grey
I had the same issue shortly after purchasing my '04 and it ended up being a faulty motor. As previously mentioned - it's an easy DIY. I bought a used motor off ebay and it's still going strong 2 yrs later. 2004 RR Westminster 4.4 V8
Bonatti Grey/Jet
Post #311300 7th Feb 2015 1:33am
defenderr
Netherlands
Thanks for that! I've not tried it yet but will later.
Hope that will work, would be better (and cheaper) than replacing parts.
Daniel
Post #311388 7th Feb 2015 5:51pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
And don't forget when reconnected battery to re set the steering angle, ie turn left and right locks to clear eas. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #311407 7th Feb 2015 7:06pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Might be way off, but had that on my E type all 3 wipers parked standing up and turned out to be the mass/ earth contact on the wipermotor, but then again I am not a tech Embarassed
Post #311412 7th Feb 2015 8:08pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
my wiper mechanism slipped on the motor shaft once when they triggered after a huge lump of snow slid down the windscreen - they were doing the same as yours, going past home position and stopping few inches up the screen.
Was a dead easy job to loosen the mechanism, re-zero it then tighten the mechanism back up.
Post #311426 7th Feb 2015 9:09pm
defenderr
Netherlands
Tried a few things but in the end the problem was solved by replacing the wiper motor.
Thanks for all the helpful suggestions!
Daniel
Post #312375 12th Feb 2015 9:52pm
