Home > Technical (L322) > Transmission Failsafe after 5 minutes + transfer box fault
AndyLandy
Hi folks, is there any particular significance to a transmission fail-safe message after 5 minutes of driving? The car also has a transfer box fault and from reading various threads this can bring on the tx fail-safe mode (associated with an incorrect output value from the rotary potentiometer in the hi/lo select motor). Does it take 5 minutes of driving for the ecu to decide there is a speed mismatch with the output shaft sensor when compared to the speed expected due to being in lo range for example?
Post #312322 12th Feb 2015 5:10pm
First thing to check is battery condition and voltage, the gearbox ECU is very sensitive to low volts... Pete
-Click here for Thread-
Post #312399 13th Feb 2015 12:37am
