![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Balki Member Since: 13 Nov 2014 Location: Tasmania Posts: 35 ![]() ![]() |
Unnecessary quote removed
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I've a pal with a 2004 hse and is interested is there a direct link to the product and it should go in straight from the box right? as he's got the old single cd in dash and glovebox stack nothing in boot |
Hi ya Bud, try this
Cheers will pass it on or even sell him mine I had off powerful a few years ago and get a new one with wifi and other adds 😜 _____________________________________________________
BigSigh Member Since: 27 May 2014 Location: Melbourne Posts: 3 ![]() ![]() ![]() |
Hi Lads,
Hi ya buddy, that's the manufacturer's site, be careful of their shipping charges, they have a nasty habit of making them up as they go. If you were in the UK and you opt for the UK to UK option I think it comes up with around £13, but if you do the shipping estimator then they want to charge you £25, that's nearly 100% more |
Righty-Ho then...
Hi, if you order that head unit it comes with just about everything that you need, the only extra will be the 6M ext. lead. You will be needing that if you have any electrical clobber in the boot on the left hand side / nearside / passenger side, assuming yours is not LHD, as I know you have the steering wheel on the correct side of the car |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 ![]() ![]() ![]() |
Ok guys here is my install so far cutting the wires
TV box? Did you order the DVB-T tuner as well? If you did it's supposed to plug directly into the head unit. USB stick videos not playing is probably the wrong file format, but I imagine that you can download a player that will work or do a file conversion |
miggit
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 ![]() ![]() ![]() |
The tv box has a small white lead that plugs in to the other end to the usb and in to the head unit marked 16 on the pic
I have the White lead pluged in but when I push tv on the HU nothing zilch nada |
