Home > Maintenance & Mods (L322) > Dead diagnostic socket
Page 2 of 4 <1234>
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I will give AJR a call tomorrow - it may well have been the headlamp self levelling ECU, I'll find out how they resolved it and post their solution 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #268017 29th Jun 2014 4:16pm
Thanks Thumbs Up
Post #268028 29th Jun 2014 5:13pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I had the same prob with drivers side headlight ecu and reader would only read some of the ecus so I unplugged the headlight one and the reader found all the other ecus and told me the headlight one was not found. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #268059 29th Jun 2014 9:04pm
adigorn
Its usually can short killing all comms
so yes unplugging and cleaning dogy connector will bring the comms
(do not reconnect )
Post #268060 29th Jun 2014 9:13pm
Well, just spent an hour looking for the elusive headlamp leveling ecu, no sign of it, turns out that according to RAVE it was only fitted to cars with Vin numbers 2A100042-3A117361.
As my car is outwith these numbers I assume it isn't fitted with one, although the cabling to the headlights seems to be there. Is it possibly located elsewhere to that shown in Rave?
Back to the drawing board. Rolling Eyes Smile
Unplugged both headlights still no joy. Censored
Post #268132 30th Jun 2014 10:08am
adigorn
passenger (LHS) A pillar (under little plastic cover under dash)
pink connector (if its there)
Recentaly had 04 4a with same issue and it was there Wink
Post #268142 30th Jun 2014 11:15am
Which plastic cover, the black one with the footwell light in it or the black trim that sits vertically around the bottom of the door opening? Doesn't seem to be in either position, certainly no pink connectors. My Vin is 4A.....
This is it shown in RAVE
Seems I am not alone having a dead diagnostic socket, the plot thickens
http://www.landyzone.co.uk/lz/f10/diagnost...56950.html
Post #268148 30th Jun 2014 11:48am
adigorn
you are looking in the right place seems no luck this time Big Cry
Post #268213 30th Jun 2014 5:32pm
The holes for mounting the ecu are in the side panel and it appears there is a headlight level ecu is fitted somewhere as the cables go into each of the headlights unless the harness wasn't modified when the ecu was omitted.
It seems that the ecu may have been repositioned at some time either by LR as a modification or by the previous owner which I doubt.
From my reading it does seem the dead socket may well be caused by a fault in either the i bus or k bus, probably as a result of corrosion in a connector plug at an ecu. The question is where, not all the ecu plugs are liable to corrosion, most are inside the car. By any chance are the headlight ecu/ballasts a known problem due to corrosion?
Post #268214 30th Jun 2014 5:43pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Try the following, turn the key to the ON position and proceed with measuring the voltage between pin 5 and 8 of the OBD port using a volt meter. Repeat the same process between pin 5 and 7.
Cheers
Post #268427 1st Jul 2014 7:11pm
Yes I can do that, can you tell me which way the pins are numbered.
Thanks Thumbs Up
Post #268442 1st Jul 2014 8:21pm
Does this help ?
Also what voltages to expect, just 12v+ ? .
Post #268447 1st Jul 2014 8:30pm
Certainly does help, Thanks Thumbs Up
I'll post what voltages I get tomorrow, I'm intrigued Smile
Post #268452 1st Jul 2014 8:39pm
Wow........me..........helping NDFI with an electrical problem Rolling with laughter Rolling with laughter Rolling with laughter .
Post #268456 1st Jul 2014 8:42pm
 2008 MY Supercharged
Post #268493 2nd Jul 2014 1:24am
Page 2 of 4 <1234>
