![]() | Home > Maintenance & Mods (L322) > Dead diagnostic socket |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I will give AJR a call tomorrow - it may well have been the headlamp self levelling ECU, I'll find out how they resolved it and post their solution 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
Thanks |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
Its usually can short killing all comms
Well, just spent an hour looking for the elusive headlamp leveling ecu, no sign of it, turns out that according to RAVE it was only fitted to cars with Vin numbers 2A100042-3A117361.
passenger (LHS) A pillar (under little plastic cover under dash)
Which plastic cover, the black one with the footwell light in it or the black trim that sits vertically around the bottom of the door opening? Doesn't seem to be in either position, certainly no pink connectors. My Vin is 4A.....
you are looking in the right place seems no luck this time |
The holes for mounting the ecu are in the side panel and it appears there is a headlight level ecu is fitted somewhere as the cables go into each of the headlights unless the harness wasn't modified when the ecu was omitted.
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Try the following, turn the key to the ON position and proceed with measuring the voltage between pin 5 and 8 of the OBD port using a volt meter. Repeat the same process between pin 5 and 7.
Yes I can do that, can you tell me which way the pins are numbered.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
Does this help ?
Certainly does help, Thanks |
Wow........me..........helping NDFI with an electrical problem |
