![]() | Home > Maintenance & Mods (L322) > Howto: FFRR TD6 '02 Replace Front and Rear Brake Lines |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 173 ![]() ![]() ![]() |
Hi Joe,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
If memory serves me correctly, the FFRR has DIN flares
ptjs1 Member Since: 15 Nov 2016 Location: Kent Posts: 10 ![]() ![]() ![]() |
It's unfortunately time for me to do this job with a major leak in one of the two pipes running Front to Rear.
You should be able to move/"re-shape" the heatshield out of the way to get to those bolts? .
Thanks for the suggestion. Maybe the exhaust is very different on a Supercharged Petrol V8? The heatshield can only be moved a max of 1/4", which isn't even giving me direct line of sight to those 2 nuts.
PatrickG Member Since: 27 Aug 2018 Location: Michigan Posts: 3 ![]() ![]() ![]() |
I removed all of the heat shield screws and used a 24" socket extension to remove those two nuts. My heat shield has a hole in it that seems like it was put there just for accessing them. Still required some forcing and bending to lower the tank cover though. '08 SC here btw.
Patrick,
OK, confirmed that the genuine pipes come pre-formed which does have some advantages. Although I sense I'll still have to put a join in to fit that over-axle pipe.
Paul,
Thanks Patrick,
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 192 ![]() ![]() ![]() |
Well that willl give me something to do, the O/S R brake pipe broke whilst parked in the yard, noticed a wet spot by the rear wheel and found the line holed making a mess of the wheel etc.
I should have concluded this in August but the whole episode was so painful, I decided to take a break!
