Home > Maintenance & Mods (L322) > Howto: FFRR TD6 '02 Replace Front and Rear Brake Lines |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
Hi Joe,
16th Jun 2023 6:49pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
If memory serves me correctly, the FFRR has DIN flares
17th Jun 2023 3:11pm |
ptjs1 Member Since: 15 Nov 2016 Location: Kent Posts: 9 |
It's unfortunately time for me to do this job with a major leak in one of the two pipes running Front to Rear.
26th Feb 2024 6:09pm |
You should be able to move/"re-shape" the heatshield out of the way to get to those bolts? .
26th Feb 2024 11:24pm |
Thanks for the suggestion. Maybe the exhaust is very different on a Supercharged Petrol V8? The heatshield can only be moved a max of 1/4", which isn't even giving me direct line of sight to those 2 nuts.
27th Feb 2024 12:05am |
PatrickG Member Since: 27 Aug 2018 Location: Michigan Posts: 3 |
I removed all of the heat shield screws and used a 24" socket extension to remove those two nuts. My heat shield has a hole in it that seems like it was put there just for accessing them. Still required some forcing and bending to lower the tank cover though. '08 SC here btw.
28th Feb 2024 2:57pm |
Patrick,
28th Feb 2024 3:17pm |
OK, confirmed that the genuine pipes come pre-formed which does have some advantages. Although I sense I'll still have to put a join in to fit that over-axle pipe.
28th Feb 2024 4:13pm |
Paul,
28th Feb 2024 4:32pm |
Thanks Patrick,
28th Feb 2024 5:01pm |
