Home > Maintenance & Mods (L322) > Howto: FFRR TD6 '02 Replace Front and Rear Brake Lines
Page 4 of 4 <1234
Bingo_123
Thanks Joe, thats good to know.
wanted to replace the rear sections only as the front ones arent showing any signs of corrosion.
Post #666696 15th Jun 2023 5:24pm
Bingo_123
Hi Joe,
Can you confirm whether flares on original steel brake pipes are single flare or double. It's a 07 MY tdv8.
Thanks
Post #666797 16th Jun 2023 7:49pm
If memory serves me correctly, the FFRR has DIN flares
These connected up and sealed OK with my bog standard replacement connectors, and I used both single and double flares when connecting up to the FFRR connectors, depending on the fitting. .
Post #666855 17th Jun 2023 4:11pm
ptjs1
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Java Black
It's unfortunately time for me to do this job with a major leak in one of the two pipes running Front to Rear.
However, I'm struggling to get past the early steps as I can't seem to be able to access the two nuts securing the left hand tank cover. These are the 2 nuts on the inside, up high and obscured by the heatshield. I've got the heatshield unbolted but it really allows very little access to get to those inner 2 nuts. Has anyone got any tips or is it easier to drill out the rivets in the bottom of the tank cover? It seems that those 2 bolts are securing a bracket that then seems to come down to the bottom of the cover and attached via the 2 rivets.
Tks for any thoughts or tips on this.
Paul
Post #686509 26th Feb 2024 7:09pm
You should be able to move/"re-shape" the heatshield out of the way to get to those bolts? .
Post #686545 27th Feb 2024 12:24am
ptjs1
Thanks for the suggestion. Maybe the exhaust is very different on a Supercharged Petrol V8? The heatshield can only be moved a max of 1/4", which isn't even giving me direct line of sight to those 2 nuts.
I really don't want to try and disassemble the exhausts. The car is obviously built with the covers first, the heatshields second, then the exhaust.
I'll have another look tomorrow if it's not raining.
Cheers
Paul
Post #686548 27th Feb 2024 1:05am
PatrickG
United States 2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I removed all of the heat shield screws and used a 24" socket extension to remove those two nuts. My heat shield has a hole in it that seems like it was put there just for accessing them. Still required some forcing and bending to lower the tank cover though. '08 SC here btw.
Some things I learned during my rusty/broken brake line repair project:
Nicopp or similar is the way. A 25' roll is enough to replace from the front fender unions back to the rear hoses if no do-overs are needed. I finished with about 18" left over.
Flares are DIN single/bubble. Capri tools CP21110-SD works well.
Put the fitting on the pipe before you flare it.
The torque to release the fittings was surprisingly low. Tightened new fittings similarly. No leaks.
Big fitting is left. Small fitting is right. (Front unions)
The fuel tank cover does not have to be completely removed.
Split the long line that goes over the fuel tank into two pieces with a union. Shorter line can be done in one piece.
There doesn't seem to be a viable source for the plastic nut things that fasten the plastic cover / line clips. Drilling out the stubborn ones was a bad decision in hindsight. Yay zip-ties.
Gap IID tool gives access to ABS bleed routine. Bring a 12v power source and lots of DOT4. Routine is long. The cycle does all four calipers. Didn't firm up the ever-mushy pedal. YMMV.
Consider engraving "Install Fitting First" on your flaring tool.
Post #686684 28th Feb 2024 3:57pm
ptjs1
Patrick,
You're absolutely right. I've finally got the tank cover out this morning.
After continually fighting with that heatshield to get access, I realised that the only route on an S/C V8 was to go through that small access hole in the heatshield. The problem, as you will have discovered, is that you're working blind once you've threaded a socket and long extensions through the hole. I used a torch and looked through the hole to orient myself. I then used a 10mm 1/4" drive socket. To this I attached a short 1/4" drive wobble bar extension and then another longer 1/4" wobble bar extension. These were necessary because you're not aligning straight to either of those 2 10mm nuts.
Eventually I extracted them. Although I have no idea how I'm going to position them on refit! I then struggled on and finally managed to get the tank cover out. Whilst the joints to the flexis (which I'm going to change as well) are soaking in WD40, I've now got a decision to make:
1. Do I purchase the pipes from Land Rover (relatively cheap and will have the new fittings)? Do they come fully shaped, or do I have to bend them? If they are pre-shaped, that could save a lot of hassle for relatively little money. If they are not pre-shaped, I won't go down this route.
2. If I purchase the new pipes, do I then cut the over-axle one and put a join in to ease refitment? Flaring the new join will be a bit more difficult on the steel pipe, but should be manageable. Where exactly is the best place to put that join?
3. Or do I go down the home-made copper pipe route, (which would be cheaper), reinstall the original fittings and also put a join in for the over-axle pipe? More work and the bends will never be as good as the originals, but may be easier to get that over-axle pipe in.
Decisions....
Paul
Post #686685 28th Feb 2024 4:17pm
ptjs1
OK, confirmed that the genuine pipes come pre-formed which does have some advantages. Although I sense I'll still have to put a join in to fit that over-axle pipe.
So, original pre-formed, or make my own?
Paul
Post #686691 28th Feb 2024 5:13pm
PatrickG
Paul,
I split the long line in the area between the fuel tank cover and the long side cover. Don't know if that will be the best place but it was practical.
I will probably never use the steel lines again. Even pre-bent. That nicopp changed me. So easy to work with.
My project at the moment.
Post #686695 28th Feb 2024 5:32pm
ptjs1
Thanks Patrick,
Whilst spraying the flexi-hose connections with lubricant, I've realised that the flexi is actually a 3-part pipe with a rigid pipe fixed between 2 flexis. Presumably even more of a pain to fit, especially as I have limited ability to raise the car!
I wonder now whether my best approach is to fit the new pipe and flexi for the left rear wheel (it's this pipe which has rusted); then leave all the covers and wheelarch liners off and drive the car 12 miles to a friends workshop where I have access to a 4-post lift to fit the other over-axle pipe and flexi?
At least I'm starting to understand how to build a S/C Range Rover:
Step 1. Take 2 long brake pipes
Step 2. Build rest of car around those 2 pipes
Cheers
Paul
Post #686697 28th Feb 2024 6:01pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Well that willl give me something to do, the O/S R brake pipe broke whilst parked in the yard, noticed a wet spot by the rear wheel and found the line holed making a mess of the wheel etc.
Joe90 guide to the rescue. Bow down
Post #712153 18th Feb 2025 5:23pm
ptjs1
I should have concluded this in August but the whole episode was so painful, I decided to take a break!
In summary, I ordered both of the front-to-rear pipes from Land Rover, partly because they are relatively cheap, and because I knew they would have all the exact bends in place. A disaster.....
The first ones turned up and the front left to offside rear was very bent and distorted as some ham-fisted employee had tried to cram it into a box that that couldn't take a pipe that size. And it's a very big box! I complained and another one was despatched. Same problem. Again and again and again.....
After 6 attempts, 6 distorted pipes, and multiple complaints to LR, I gave up and they refunded my money. Fortunately, in some ways, the pipe has to be cut around the rear left corner as you can't get the old one out or fit a new one without cutting it, as others here have realised. The original pipe is installed at such an early build stage of the car, before fuel tank, drive line, axle, suspension etc are fitted. In fact, I've even suggested to LR that there is no point now making the pipe in one piece and it should be manufactured as a 2-part pipe with a join.
So, I cut up and straightened some of the damaged replacement pipes and got two useable pipes to fit with a joining block in between. I cut the old pipe for removal, and the new pipes for fitment, just in front of the left rear wheel. See pic of the cut of the old pipe before removal.
The axle cross-over part of the pipe is an absolute pain to get in place but I eventually managed it with the vehicle on a 4-post. With new flexis then installed, I bled the brakes and refitted the fuel covers etc (what a pain that is as well!!)
So after 4 months, the job was finished and I hope I never have to do it again!
Paul
Post #712211 19th Feb 2025 11:47am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Quote:
LR had kindly used a larger fitting on one of the pipes, so will have to reuse this as I don't have any!
Quote:
(Suppose I should have put a normal sized fitting in the picture too!) Worth knowing though, if you plan to do any work in this area, to check what parts you may need.
Would anyone know the size of the larger fitting in the N/S wheel arch of the rear lines ?
Also, is the regular sized fitting M10x1mm the same as the flex line fittings ?
Lastly; on a TDV8 4.4 2012 are the Flares DIN ? ( it looks like it from the photo but this is a of a 2002 TDV6. ) TDV8 4.4 2012
Post #717033 28th Apr 2025 11:44pm
PatrickG
Larger fitting on my 2008 4.2 is M12x1. Others are M10x1. All flares are DIN bubble.
Post #717128 30th Apr 2025 3:15am
Page 4 of 4 <1234
