Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
I've had no issues with the amazon ones, but the link says they are currently unavailable, so the choice may be simpler now.....
22nd Aug 2014 6:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Mine are fine and have had thus far no negative effects |
22nd Aug 2014 12:33pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Thank you Craig |
22nd Aug 2014 7:36pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Following A11EXU's example...fitted a set of LED's inside the reverse light cluster...30 minutes work and easily put back to standard if required.
19th Sep 2014 8:14am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
any warning lights on dash ? are the led strips canbus or normal ? as ive got similar to these, will they work or give warning issues?
19th Sep 2014 10:47am |
Scottyav...No warnings for the ones I purchased....I got 2 sets of these (2 units side by side in each cluster)>>
19th Sep 2014 10:52am |
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 |
I'm loving your work Paul....
19th Sep 2014 12:06pm |
SS...Yes, thats a great idea..wish I had done that
19th Sep 2014 2:07pm |
Appreciate that Paul
19th Sep 2014 2:16pm |
Difficult to say...i'm a "more is better" man myself GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
19th Sep 2014 2:52pm |
Heated the light units over the cooker flame and the lens prised away easily tbh, stuck two pads in each lamp re sealed the lens back with a good crystal silicone pulled wires out of the back and they come with all attachments to put in any holder so no need to butcher anything, put reverse in looked bright so couldn't wait till later when I came back so took a few pics of the brightness now and looks fine to me the bottom ones like daylight and it's really dark here at 10-45pm lol 😎😎😎
20th Sep 2014 10:02pm |
That looks impressive.
20th Sep 2014 11:39pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Now they do look bright |
21st Sep 2014 12:03am |
Nice job....Can you see the LEDs thru the lens when off Scottyav? or did you find a fix to that?
21st Sep 2014 8:27am |
