Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 7 of 22 <123 ... 678 ... 202122>
mjdronfield
I've had no issues with the amazon ones, but the link says they are currently unavailable, so the choice may be simpler now.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #277020 22nd Aug 2014 6:07am
pld118
Thanks Mark, you'll do for me.
I've asked AF if they've got anywhere with LED options and a reply is pending although I've noticed CTC has today made an observation about small margins for error and reverse bulbs being ineffective if not seated spot on.
Post #277095 22nd Aug 2014 12:24pm
Mine are fine and have had thus far no negative effects Thumbs Up
Post #277098 22nd Aug 2014 12:33pm
pld118
Thank you Craig Thumbs Up
Post #277162 22nd Aug 2014 7:36pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Following A11EXU's example...fitted a set of LED's inside the reverse light cluster...30 minutes work and easily put back to standard if required.
Day and Night shots...certainly seems brighter
 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #281844 19th Sep 2014 8:14am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
any warning lights on dash ? are the led strips canbus or normal ? as ive got similar to these, will they work or give warning issues?
http://www.ebay.co.uk/itm/1-5x-Car-Interio...51b9d1b9ae _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #281865 19th Sep 2014 10:47am
paulmoran2
Scottyav...No warnings for the ones I purchased....I got 2 sets of these (2 units side by side in each cluster)>>
http://www.ebay.co.uk/itm/360853296613?ssP...1497.l2649
You have to cut (or dare I say it, scotch-lock) into the wires as these don't have the bayonet adapter which would have been easier.
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #281866 19th Sep 2014 10:52am
Silversurfer13
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
I'm loving your work Paul....
A few questions if I may though....
As they're as bright as they are, will 1 strip in each housing suffice?
Does the black surround look like it can be painted white (or silver to not stand out).
How come they don't have to be CanBus?
Has anybody come up with a simple CanBus LED replacment bulb without having to undero any chopping / splicing / etc. etc. etc.......?
Any recommendations on a suitable LED number plate light replacement - that's not much brighter than the original?
Post #281878 19th Sep 2014 12:06pm
paulmoran2
SS...Yes, thats a great idea..wish I had done that Big Cry
You will still be able to see the yellow COB led through anyway, but the chassis of the unit would look better whited out. I have 3M tape on mine so it covers some of the black.
I didn't get any errors come up using these unit (is the reverse on canbus system?) but time will tell.
I had some LED units on the front fogs before, and as the units aged, the error came up, so I just turned HOT/COLD monitoring to OFF on those lights using the IID tool ,so the error went off.
Advanced Factors (site sponsor) now do a range of LED bulbs, so check them out for the number plate light, then you can "illuminate" us all with that information Thumbs Up
Post #281905 19th Sep 2014 2:07pm
Silversurfer13
Appreciate that Paul
Would 1 strip suffice on each side?
Post #281906 19th Sep 2014 2:16pm
paulmoran2
Difficult to say...i'm a "more is better" man myself GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #281917 19th Sep 2014 2:52pm
Scottyav
Heated the light units over the cooker flame and the lens prised away easily tbh, stuck two pads in each lamp re sealed the lens back with a good crystal silicone pulled wires out of the back and they come with all attachments to put in any holder so no need to butcher anything, put reverse in looked bright so couldn't wait till later when I came back so took a few pics of the brightness now and looks fine to me the bottom ones like daylight and it's really dark here at 10-45pm lol 😎😎😎
I used two of these for each side off eBay 😋 http://www.ebay.co.uk/itm/390856018367?_tr...EBIDX%3AIT
Post #282038 20th Sep 2014 10:02pm
mjdronfield
That looks impressive.
Mine have been in ages, as you can see by my previous posts, but I've still not reversed in the dark with them properly yet...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #282045 20th Sep 2014 11:39pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Now they do look bright Thumbs Up
Post #282047 21st Sep 2014 12:03am
paulmoran2
Nice job....Can you see the LEDs thru the lens when off Scottyav? or did you find a fix to that?
P GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #282069 21st Sep 2014 8:27am
