Home > Technical (L322) > TD6 2002 wont start
Batpooh
United Kingdom 2002 Range Rover Vogue Td6 Galway Green
TD6 2002 wont start
Hi All first post and as usual its a cry for help Bow down
I have 2002 td6 and it has developed a problem put the key to position 1 and a whole load of the electrics pulse on/off try to crank and you sometimes get a slight click but that's it!
The battery is good and fully charged (my first thought) , then i did a bit of research on this site (and others Whistle) & it would appear there were a few possibility's
1. starter motor, I had one of these so thought i would just swop this over and then i can eliminate this as a possibility. done and no change
2. Ignition switch, is there any way of testing this? method etc
3. Gearbox position inhibitor switch so have tried in neutral, park shake it all about, no change
is there anything that could be inhibiting the system?
i have taken what is probably not a very good video of the symptoms so you can see whats occurring see this link http://s153.photobucket.com/user/Batpooh/library/Strange%20Rover
any help and advice would be really welcome and thank you in advance
Stuart
Post #239039 2nd Feb 2014 7:40pm
That's a good way of describing the problem - with a video.
Sorry - I don't have an answer though. I suspect someone else will soon.
Post #239062 2nd Feb 2014 8:21pm
To eliminate gear selector cable stiffness / corrosion holding off the gearbox inhibitor switch I would be inclined to lubricate the cable as per the link below,
http://www.fullfatrr.com/forum/post87201.html#87201
Video is very useful, you may have started something. Thumbs Up
Post #239069 2nd Feb 2014 8:42pm
Video very handy.
The clicking relay is the glow plug relay. This is unlikely to be the problem, unless if it fails it causes these symptoms (but I do not believe that would happen - the car should just turn over and not start if the glow plug relay packed up - or take longer to start - see my thread on this).
Have you tried battery disconnection procedure and do as above and ensure gear lever linkage is working OK.
Any diagnostic tools available for fault codes? .
Post #239078 2nd Feb 2014 9:17pm
Batpooh
sorry no diagnostics etc
and yes i have disconnected the battery and connected the leads to kill everything down reconnect exactly the same.
If the that's the glow relay then i should be able to figure out what its fed via, yes?
may help
i dunno Censored
Stuart
Post #239089 2nd Feb 2014 9:35pm
Easiest thing to do is unplug it and see what happens?
( I have not tried this, do not know what it might do) .
Post #239094 2nd Feb 2014 9:45pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Could it be a bad earth? Try putting a jump lead from the negative on the battery to the engine. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #239460 3rd Feb 2014 10:55pm
Batpooh
Sorry for the delay,
no not a bad earth
unfortunately still no go and the battery's flat now Censored haven't had a chance to work on it this week but it appears to have discharged a fully charged battery in 7 days.
I have a fluke multi meter that can measure DC Current up to 10A what sort of draw would I expect with the car locked and just sitting there?
cheers for your help guys
Stuart
Post #241285 9th Feb 2014 10:58am
When you first lock the car you could see 6-7A being drawn from the battery, possibly slightly more of the FBH has been running whilst it goes thro its purge cycle.
After about 30s the current drain should drop significantly to about1-2A.
After that the current drain drops off slowly as each ECU shuts down, after about 10minutes you should be reading below 1A.
Your car should ultimately settle to about 40mA after it has gone fully to sleep.
If the readings show above this it tends to indicate a current drain which shouldn't be there.
Have you considered the "pulsing" is caused by a bad connection.?
Post #241294 9th Feb 2014 11:24am
Batpooh
So i should get a reading of 0.03 amps on the fluke Thumbs Up
OK i will go and check Cheers
Also how do i get to the ignition switch is there an entry in the manual describing the sequence as im starting to suspect this component more and more and i don't want to break all the plastic etc Big Cry
cheers
Stuart
Post #241313 9th Feb 2014 12:14pm
wats39
Still think its a bad connection somewhere. If you look at the instrument panel the only light thats flashing is the oil light which points the problem towards the engine side of things in my opinion. The relay thats ticking in the engine compartment is the glowplug relay which draws quite a bit of current. Double check all your main earth and power cables for good connections. Check the main fuses by pulling them out and checking their terminals are clean etc. Remember to disconnect the battery first though. If it were the ignition switch then i would imagine all the warning lights would be flashing???? Good luck Thumbs Up '04 td6 se
Post #241561 9th Feb 2014 11:00pm
Try this,
find a diesel car to give you a jump start but leave the leads on from it for about 10minutes before you try and crank yours over as it will need that time to bring it up.
Even if the battery is showing as good it could be just poor enough for the car to kick up a fuss.
It'll take a few minutes to test and is worth the effort Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #241638 10th Feb 2014 12:35pm
Noddysvogue
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Hi Stuart I've noticed the hill decent is lit on your clocks has it always done that as mine doesn't light on start
Ian
Post #243426 18th Feb 2014 7:36pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
As Ian says and also the oil light is flashing, dont think mine flashes like that.
Grant
Post #243563 19th Feb 2014 4:22am
Batpooh
Hi Folks
OK update been waiting a week and a half for a ignition switch contact set to arrive part no YXB 000080 Very Happy
Got it today, went to fit (after much Censored about to get the center console off) fitted onto the lock went to plug in the electrics and it wont fit Sad
the keying is all different in the sockets has anyone else encountered this problem?
The switch looks exactly the same the cam looks identical cant see any difference except the keying Big Cry
bloody annoyed now Censored
Have i got the right part no?
Stuart
Post #244102 21st Feb 2014 6:11pm
