Home > Technical (L322) > TD6 2002 wont start |
Batpooh Member Since: 28 Jan 2014 Location: Aylesbury Posts: 13 |
Hi All first post and as usual its a cry for help
2nd Feb 2014 7:40pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
That's a good way of describing the problem - with a video.
2nd Feb 2014 8:21pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
To eliminate gear selector cable stiffness / corrosion holding off the gearbox inhibitor switch I would be inclined to lubricate the cable as per the link below,
2nd Feb 2014 8:42pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Video very handy.
2nd Feb 2014 9:17pm |
Easiest thing to do is unplug it and see what happens?
2nd Feb 2014 9:45pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
Could it be a bad earth? Try putting a jump lead from the negative on the battery to the engine. '04 td6 se
3rd Feb 2014 10:55pm |
Sorry for the delay,
9th Feb 2014 10:58am |
When you first lock the car you could see 6-7A being drawn from the battery, possibly slightly more of the FBH has been running whilst it goes thro its purge cycle.
9th Feb 2014 11:24am |
So i should get a reading of 0.03 amps on the fluke
9th Feb 2014 12:14pm |
Still think its a bad connection somewhere. If you look at the instrument panel the only light thats flashing is the oil light which points the problem towards the engine side of things in my opinion. The relay thats ticking in the engine compartment is the glowplug relay which draws quite a bit of current. Double check all your main earth and power cables for good connections. Check the main fuses by pulling them out and checking their terminals are clean etc. Remember to disconnect the battery first though. If it were the ignition switch then i would imagine all the warning lights would be flashing???? Good luck '04 td6 se
9th Feb 2014 11:00pm |
Try this,
10th Feb 2014 12:35pm |
Noddysvogue Member Since: 01 Feb 2014 Location: Blackpool Posts: 4 |
Hi Stuart I've noticed the hill decent is lit on your clocks has it always done that as mine doesn't light on start
18th Feb 2014 7:36pm |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
As Ian says and also the oil light is flashing, dont think mine flashes like that.
19th Feb 2014 4:22am |
Hi Folks
21st Feb 2014 6:11pm |
