Home > In Car Electronics (L322) > Dash camera fitment
Page 5 of 8 <12345678>
I wonder how the law looks upon cars with infra red night vision?
Surely that constitutes the same level of risk as a camera showing the same view, but in the visible light spectrum? Got - 2017 SDV8 Autobiography in Loire Blue
Post #266106 18th Jun 2014 2:35pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Welshdragon thanks for the reply. I did see your excellent post earlier, but alas F7 on my bus is already taken up, and shuts down when the vehicle goes to sleep. However I shall persevere and if push comes to shove I'll come straight of the battery .
Post #266232 19th Jun 2014 12:29pm
Prop
Silversurfer, I am curious as to why you want a permanent live even after the car shuts down. This would mean the dashcam would record permanently and never turn off. This could possibly flatten the car battery during long periods of the car not being used.
Most dashcams I am aware of start recording when the ignition is turned on and stop about 1 minute after the ignition is turned off. I guess you may have your reasons but thought it worth a mention.
Post #266430 20th Jun 2014 12:23pm
the socket in the rear luggage compartment stays live all the time.. ... - .- -.
Post #266431 20th Jun 2014 12:42pm
silversurfer
The camera is activated by a motion sensor ,and turns itself on and off .and yes the possibility of a flattened battery did
cross my mind.
I appreciate your thought.
Post #266461 20th Jun 2014 4:33pm
silversurfer
Thank you for that Mr Moderator. Thumbs Up
Post #266462 20th Jun 2014 4:35pm
silversurfer
Dash Camera Fitmentt
When fitting a dash camera and hard wiring it, what size fuse should I use when using a blade piggy back holder?
Would 3amp be okay?
Cheers
Post #269472 7th Jul 2014 9:57am
3 amp is best.. Thumbs Up ... - .- -.
Post #269477 7th Jul 2014 10:16am
silversurfer
Top man Stan. Thumbs Up Thank you.
Post #269527 7th Jul 2014 3:40pm
Just check that rear power socket , I think it only stays powered for twenty minutes after ignition off . 2008 MY Supercharged
Post #269594 7th Jul 2014 10:31pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I always thought the rear aux was a permanent live. I hope it is, that's what I have my battery trickle charger plugged into! But you've got me thinking now........ 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #269597 7th Jul 2014 11:00pm
mine is defo permanant live..... Thumbs Up ... - .- -.
Post #269606 8th Jul 2014 7:13am
CADjockey
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
On this general topic, I see that in common parlance 'there's an app for that'... (a few actually)
Has any one had any experience with a smartphone based dash cam, notwithstanding the
obvious visible screen issue? 2010 FFRR VOGUE TDV8 Stornoway Grey - Current
2008 RRS HSE TDV6 Zermatt Silver - 163k - Gone...
Post #269615 8th Jul 2014 7:51am
there's talk about that kinda system here,
http://www.fullfatrr.com/forum/topic19780.html?highlight=dashcam ... - .- -.
Post #269618 8th Jul 2014 8:50am
blacknwhitemike
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Hi guys
Been following the method installing a dash cam and found it simple and easy to follow.
However hit a problem with the fuse bypass. The suggested fuse 7 is already taken by the air suspension (that I daren't touch! Shocked ) - but of course I have an 2007 TDV8 Vogue SE, so there are going to be electrics differences(?)
So if anybody has the same car and fitted a dash cam, would you let me know what fuse you used please?
Thanks
Mike -----------------------------
Current:
2007 TDV8 3.6 Vogue SE Zermatt Silver
Past:
1999 2.5 dHSE Rioja Red
1994 3.9 British Racing Green
1992 3.9 Aegean Blue
1986 3.5 Green
1974 3.5 Lincoln Green
Post #273394 29th Jul 2014 10:02am
