Home > In Car Electronics (L322) > Dash camera fitment |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 |
Welshdragon thanks for the reply. I did see your excellent post earlier, but alas F7 on my bus is already taken up, and shuts down when the vehicle goes to sleep. However I shall persevere and if push comes to shove I'll come straight of the battery . |
19th Jun 2014 12:29pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Silversurfer, I am curious as to why you want a permanent live even after the car shuts down. This would mean the dashcam would record permanently and never turn off. This could possibly flatten the car battery during long periods of the car not being used.
20th Jun 2014 12:23pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
the socket in the rear luggage compartment stays live all the time.. ... - .- -.
20th Jun 2014 12:42pm |
The camera is activated by a motion sensor ,and turns itself on and off .and yes the possibility of a flattened battery did cross my mind. I appreciate your thought. |
20th Jun 2014 4:33pm |
Thank you for that Mr Moderator. |
20th Jun 2014 4:35pm |
When fitting a dash camera and hard wiring it, what size fuse should I use when using a blade piggy back holder?
7th Jul 2014 9:57am |
3 amp is best.. ... - .- -.
7th Jul 2014 10:16am |
Top man Stan. Thank you. |
7th Jul 2014 3:40pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Just check that rear power socket , I think it only stays powered for twenty minutes after ignition off . 2008 MY Supercharged
7th Jul 2014 10:31pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
I always thought the rear aux was a permanent live. I hope it is, that's what I have my battery trickle charger plugged into! But you've got me thinking now........ 2006 4.2 SC
7th Jul 2014 11:00pm |
mine is defo permanant live..... ... - .- -.
8th Jul 2014 7:13am |
CADjockey Member Since: 24 Jun 2014 Location: West Midlands Posts: 19 |
On this general topic, I see that in common parlance 'there's an app for that'... (a few actually)
8th Jul 2014 7:51am |
there's talk about that kinda system here,
8th Jul 2014 8:50am |
blacknwhitemike Member Since: 11 May 2014 Location: Devon Posts: 5 |
Hi guys
29th Jul 2014 10:02am |
