![]() | Home > Maintenance & Mods (L322) > New brakes have arrived |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
I replaced my discs and pads following this guide yesterday.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
So true.
MAF260 Member Since: 02 Mar 2017 Location: Hertfordshire Posts: 25 ![]() ![]() |
I replaced the front discs and pads on my 4.4TDV8 recently. As described, a very easy job.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
MAF, they had a 70% off a couple of weekends back Current: 2011 FFRR Vogue SE 4.4 TDV8
19sjw Member Since: 18 Oct 2014 Location: East Anglia Posts: 25 ![]() ![]() ![]() |
When I did my pads etc,the pins that hold the retaining spring in place were stainless steel,I think they are standard ,although I did replace the bleed nipples with stainless ones, the front Brembos that is. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Just done my drivers side, no wear sensor to be found!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Sensor only fitted on passenger side front brake.
RHC Member Since: 06 Feb 2015 Location: Yorkshire Posts: 26 ![]() ![]() |
I thought you may like to see the before and after of the reconditioned calipers (new pads fitted as well)It was part of a full detailing.
Thanks Mike!
RHC you've definitely spilt your Range Rover there, I saw the detailing shots on the other thread!
Thanks, I'm very, very, pleased with it. |
MadL322 Member Since: 10 Oct 2018 Location: Yeovil Posts: 108 ![]() ![]() ![]() |
Never thought of a scaffold board type wood to give the jack that extra inch or so to get off the ground, my jack only just raises high enough to get the wheel of with a squeeze, so a couple of blocks will become part of the maintenance kit lol |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
If you have the performance brakes
