![]() | Home > Maintenance & Mods (L322) > New brakes have arrived |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35622 ![]() ![]() |
dont forget the pics.... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Brakes done,
Ok Here goes.
nice job Mark, put in our wiki.. |
I'm all set to do this tomorrow bought new Brembo discs and pads. Do you need new caliper retaining bolts as suggested in post above or can I just reuse old ones? Present :2008 TDV8 HSE
just clean the pins up and put them back.. ... - .- -.
Just did this today fitted Brembo discs and pads. Discs really did need replacing so glad I had the info as per Mark above really straight forward |
Ok so now I have a 4.4 it time to swap the brakes on that too. I did the pads and disks when I bought it a few years back but the pads have started to squeal so thy are coming out anyway.
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
I decided today to check that the pins weren't seized in the calipers. The top and bottom ones were fine; I cleaned them up and greased them with some Ceratec.
As you were doing.
Thanks NMJ, will give it another go tomorrow. |
OK, finally, job done. Great write up by NMJ, and I have nothing much to add. The middle pins are a rather odd design but just use a little brute force and they tap out (towards you on the outside of the car).
i think i'll search for 'jurid' pads when i need new instead of LR branded ones.. |
