Home > Maintenance & Mods (L322) > New brakes have arrived
Page 2 of 4 <1234>
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
Finally got round to fitting the new discs and pads on my L322, pads were well worn but the discs were shocking, one was down to 23.5mm Shocked
Took it for a test drive and gave the brakes some gentle bedding in, noticed the slight steering wobble had gone at around 55mph aswell, all in all pleased with the couple of hours work.
Post #479409 26th May 2018 2:51pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
I replaced my discs and pads following this guide yesterday.
Straight forward to do, the most difficult bit being undoing the caliper bolts as its difficult to get any real purchase on them. Soaking them in WD40 and whacking the spanner with a lump hammer did the trick.
Also had one of the pins seized so it buckled as I was drifting it out. Cutting the pin on both sides with an angle grinder, more WD40 then drifting it out did the trick.
Good job I bought the kit (part no. LR016683) from Dan at Duckworths Very Happy 2012 Westminster 4.4 TDV8
Post #489528 22nd Sep 2018 7:36am
Thumbs Up Thumbs Up
Not a difficult job so long as you have decent supports under the car. What you don't want is a RR falling on your head..... Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #489545 22nd Sep 2018 11:13am
wood78987
So true.
A Sprinter bottle jack, or even better a trolley jack and axle stands is the only way.
I wouldn't attempt this with a scissors jack as the car moves around when whacking bolts to undo them. 2012 Westminster 4.4 TDV8
Post #489548 22nd Sep 2018 11:47am
MAF260
I replaced the front discs and pads on my 4.4TDV8 recently. As described, a very easy job.
Keep your eyes open for ECP deals - brakes are often 50% off. They recently had 53% off which I've never seen before so I snapped up discs, pads, handbrake shoes and wear sensors all round for about #300. All parts are Pagid and I'm very happy with them.
Post #490070 26th Sep 2018 9:58pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
MAF, they had a 70% off a couple of weekends back Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #490071 26th Sep 2018 10:02pm
19sjw
England 2007 Range Rover Vogue TDV8 Tonga Green
When I did my pads etc,the pins that hold the retaining spring in place were stainless steel,I think they are standard ,although I did replace the bleed nipples with stainless ones, the front Brembos that is.
Post #490093 27th Sep 2018 8:18am
GGDR
Just done my drivers side, no wear sensor to be found!
Is that right, is there only one wear sensor?
Came in for a break, a bit nippy today.4 degrees out !
I'm hoping a sensor will show up when I whip off the NS wheel in an hour.....
After I've warmed up a bit!
. Cheers, Greg
Post #502097 19th Jan 2019 12:57pm
Baltic Blue
Sensor only fitted on passenger side front brake.
Post #502100 19th Jan 2019 1:21pm
RHC
2008 Range Rover Vogue TDV8 Java Black
I thought you may like to see the before and after of the reconditioned calipers (new pads fitted as well)It was part of a full detailing.
I've also posted a few photos in the 'My Range Rover' thread of the whole car after the detailing was completed.
 L322 Vogue
D3
Defender 90 - 1993
David Brown 885
All Gone: Range Rover Classic 2 Door - 1978/Land Rover Series IIA - 1964/Land Rover 90 - 1987/Land Rover Series III - Air Portable - 1979
Post #502101 19th Jan 2019 1:24pm
GGDR
Thanks Mike!
I did see that just now. Just assumed both sides!
And you know what they say about assuming!
Spare sensor either being returned or going for sale!
I bought two Banging Head
. Cheers, Greg
Post #502102 19th Jan 2019 1:26pm
GGDR
RHC you've definitely spilt your Range Rover there, I saw the detailing shots on the other thread!
That close up shot of your tailgate is unbelievable.
Drivers side done:
I now regret not getting new clips. Big Cry Still does the job and will be covered with muck soon enough I'm telling myself.
Not exactly up to your standards RHC
But I'm chuffed I've got the Greenstuffs in there now.. Cheers, Greg
Post #502103 19th Jan 2019 1:32pm
RHC
Thanks, I'm very, very, pleased with it. Very Happy Very Happy Very Happy Very Happy L322 Vogue
D3
Defender 90 - 1993
David Brown 885
Post #502107 19th Jan 2019 1:44pm
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
Never thought of a scaffold board type wood to give the jack that extra inch or so to get off the ground, my jack only just raises high enough to get the wheel of with a squeeze, so a couple of blocks will become part of the maintenance kit lol
Post #502126 19th Jan 2019 4:51pm
Rambles
Calliper bolts
If you have the performance brakes
https://rimmerbros.com/Item--i-SYG500050?g...gImwPD_BwE
A 21mm regular socket will fit
But doesn’t feel like the right tool
Any thoughts on this star type head? Triple square? 12 spline....
What is the best socket?
Given torque setting is 275 nm
Post #530512 10th Oct 2019 6:23pm
Page 2 of 4 <1234>
