Home > Maintenance & Mods (L322) > flip keys (new order started)
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 2 of 11 <123 ... 91011>
daveo
supershuttle wrote:
261050835380
Are these the same thing?
that brings up a camera not a key...you would have trouble starting your car with that V8 facelift Range Rover Autobiography 22" wheels.
Post #189221 19th May 2013 9:33am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Davao, at the risk of sounding dumb, what exactly is involved in transferring the transponder across and is this something that requires some electrician skills eg soldering etc?
Thanks African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #189245 19th May 2013 1:47pm
daveo
This is what you will be doing, from the old style fix key to the new style flip key
This is the new style flip key with land rover logo,
now this is a new style with chrome sides, I was told that they plan to the word range rover down the side just like the 2012 smart key but as yet they have not,
Now I don’t make fortunes out of these keys, we are talking a few pounds on each but it bumps up the amount of units to meet the min order.
now I am not sure on this one, these keys are to replace the 02 to 05 keys but I have had a few enquires about 06 and 07 cars having the early style key, as a replacement key the transponder chip should swap over no problem but it’s the circuit board part that unlocks your car that may not work.
Lastly these are from a good supplier and are good quality, nice metal chrome parts and not flaky chromed plastic, good buttons. And not the early ones had problems with their buttons and as another member found out when he ordered some they had the wrong key blanks and I ended up sourcing blanks for him, these have the wide blank and can be cut by timsons.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #189247 19th May 2013 1:54pm
daveo
Thanks
no its very easy,just like changing the battery, when you take apart the remote just infront of the circuit board at the key end you will see a small black chip,this it the transponder remove it and replace it into the new key, bingo your done... V8 facelift Range Rover Autobiography 22" wheels.
Post #189248 19th May 2013 1:59pm
Stryke
Worth noting that the key blades have to be laser cut.
Post #189251 19th May 2013 2:46pm
supershuttle
eBay Item No. 300907650248
I meant this Embarassed Geoff
Post #189254 19th May 2013 3:02pm
daveo
HI, thats just for a blank case, no circuit board.. V8 facelift Range Rover Autobiography 22" wheels.
Post #189255 19th May 2013 3:06pm
daveo
yes they call it lazer cut but its just done by a endmill cutter, timpsons do them,my local one charges me a fiver, they use a machine made by colt. V8 facelift Range Rover Autobiography 22" wheels.
Post #189256 19th May 2013 3:10pm
Fozzauk
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Is it possible to get new transponder chips? I have been trying to do this key update for a while now and have collected many spares and different fobs. I have an 06 facelift with the BMW key. I have got the circuit board for an 07 flip key but need a new transponder for it and it coding to the ews.
I only have one key and am looking to do this for a spare.
If not I may have to buy one of these keys and use the transponder from that with the 07 circuit board if these keys won't open the car?
Bit cheeky, would you be willing to code my ews daveo if I was to drive to you? Goes without saying there would be a few beer tokens in it for you.
Post #189257 19th May 2013 3:17pm
daveo
Ok... on the landrover flip style keys the transponder is part of the circuit board, these cannot be removed and the chances of getting a blank one is very low, when I first converted a diamond key to fit inside the flip case it was the transponder that caused the problem as it was not a blank chip as I was told and then it confuses the car resulting in your car locking the ignition out.
you say you have a 06 S/C with the old style key and that you have bought various spares, I think when they changed from late 05 the EWS changed to ford but I am not sure, if someone knows it would be great, do you have a spare circuit board from an old style key and does it program and work to your car. V8 facelift Range Rover Autobiography 22" wheels.
Post #189259 19th May 2013 4:30pm
Fozzauk
Unfortunately that is one thing that I don't have. Is the ews easily accessible and would it be identified on there as being a ford part?
Post #189264 19th May 2013 5:37pm
daveo
the EWS is located on the right side of th centre console level with the gear shift, its down the side and on the 02 to 05 looks like a grey box about the size of a ciggi packet.
Post #189267 19th May 2013 6:08pm
Fozzauk
I am away until Thursday, but will have a look when I get back home!
Post #189268 19th May 2013 6:10pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Microcat should be able to help here
Post #189291 19th May 2013 9:53pm
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I'd be very interested in 2 of the new shape keys.
Just to replace my 2 existing keys.
Post #189293 19th May 2013 10:06pm
This topic is locked: you cannot edit posts or make replies.  Back to top
