![]() | Home > Maintenance & Mods (L322) > flip keys (new order started) |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
Davao, at the risk of sounding dumb, what exactly is involved in transferring the transponder across and is this something that requires some electrician skills eg soldering etc?
This is what you will be doing, from the old style fix key to the new style flip key
no its very easy,just like changing the battery, when you take apart the remote just infront of the circuit board at the key end you will see a small black chip,this it the transponder remove it and replace it into the new key, bingo your done... V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Worth noting that the key blades have to be laser cut. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3868 ![]() ![]() ![]() |
eBay Item No. 300907650248
HI, thats just for a blank case, no circuit board.. V8 facelift Range Rover Autobiography 22" wheels.
yes they call it lazer cut but its just done by a endmill cutter, timpsons do them,my local one charges me a fiver, they use a machine made by colt. V8 facelift Range Rover Autobiography 22" wheels. 1976 Harley Davidson Iron Head Sportster |
Fozzauk Member Since: 09 Nov 2012 Location: Derbyshire Posts: 59 ![]() ![]() ![]() |
Is it possible to get new transponder chips? I have been trying to do this key update for a while now and have collected many spares and different fobs. I have an 06 facelift with the BMW key. I have got the circuit board for an 07 flip key but need a new transponder for it and it coding to the ews.
Ok... on the landrover flip style keys the transponder is part of the circuit board, these cannot be removed and the chances of getting a blank one is very low, when I first converted a diamond key to fit inside the flip case it was the transponder that caused the problem as it was not a blank chip as I was told and then it confuses the car resulting in your car locking the ignition out.
Unfortunately that is one thing that I don't have. Is the ews easily accessible and would it be identified on there as being a ford part? |
the EWS is located on the right side of th centre console level with the gear shift, its down the side and on the 02 to 05 looks like a grey box about the size of a ciggi packet.
I am away until Thursday, but will have a look when I get back home! |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Microcat should be able to help here |
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
I'd be very interested in 2 of the new shape keys.
