![]() | Home > Maintenance & Mods (L322) > Bosch s5 silver 110ah 020 |
ECP with one of the discount codes and thats delivered as well next day or pick up if you have a local branch |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35661 ![]() ![]() |
the bosch/varta 020 is the best for the fullfat, a bit fiddly to fit but worth it especially with the 5 year warranty... ... - .- -.
I got mine to fit without any cutting. Obviously don't put it in the wrong way like I did. That gets very annoying. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
fitting is only an issue if you have the incendiary charge on the positive terminal which hangs over the side of the battery - this causes the 'clearance issues' that some of us have faced. Not all the early TDV8's had them as far as I can tell, so your TD6 is probably OK |
No problem getting an s5 110A in a td6.
Googsy's disease is spreading!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Thank you gentlemen.. S5 being ordered.
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 968 ![]() ![]() ![]() |
is this the one that i need, i am pretty sure it is but thought that i would check with you knowledgable gentlemen first.....
thats the one Andy, type 020, 110amphr,920cca...
According to that they are in preston...
cheers guys, will be getting today! |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Just checking but is this battery ok for the 4.4v8 petrol as well? (Yes it's new battery time again) "On first name terms with my local Dealer......now."
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
Is this not the same battery? I thought Varta made the Bosch batteries, which means this a pretty good deal!
it will be ideal Mr P.. |
