![]() | Home > Maintenance & Mods (L322) > Bosch s5 silver 110ah 020 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
In case you don't know - you can open your bonnet wider - and it makes fitting the battery much easier.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
^ it's in the WIKI.....
noworries4x4 Member Since: 03 Oct 2013 Location: Newton Abbot Posts: 166 ![]() ![]() ![]() |
I have just fitted this bigger battery to my 07 tdv8, mine had a tiddly 013 in it no wonder it struggled sometimes. The battery fitted easily but the positive connector would not fit in any way shape or form. Mine does not have the jump peg on the bulkhead or the explosive disconnect, but mine does have the box with the 400amp fuse in it. I ended up putting a short jump lead in the system and the fuse is now zippy tied to the battery handles. Not the greatest solution and will look to do better in the future. I tried to heat up the clamp/bracket but it is cast brass and just broke. If everything is under control you are not going fast enough.
I know it does not look the best but it works and as other posters have said everything seams to be working a bit better/faster probably complete |
