Home > Maintenance & Mods (L322) > Bosch s5 silver 110ah 020
Page 1 of 4 1234>
I need to buy a battery today. Our 7 year old one has finally given up.. Yes, 7 year old.
Is the bosch s5 silver 110ah still the recommended upgrade to go for?
I have read loads of threads about it and it will fit. But is it worth it?
Should I not just get the S3 017 normal size battery? Is the 020 worth the hassle?
I have found �110 delivered, can anyone suggest somewhere cheaper?
Cheers
Thumbs Up Previously..
Post #169913 4th Feb 2013 10:07am
ECP with one of the discount codes and thats delivered as well next day or pick up if you have a local branch Smile
They do it for �114.83 with discount unless you can find a 30% discount code that would make it even cheaper but they are all off at the minute Sad
It requires a little cutting but well worth it in the long run as even if a cell fails in a few years time there should be enough grunt to still get a car going easily enough Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #169924 4th Feb 2013 10:28am
the bosch/varta 020 is the best for the fullfat, a bit fiddly to fit but worth it especially with the 5 year warranty... ... - .- -.
Post #169927 4th Feb 2013 10:32am
I got mine to fit without any cutting. Obviously don't put it in the wrong way like I did. That gets very annoying. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #169936 4th Feb 2013 10:43am
simon1233
fitting is only an issue if you have the incendiary charge on the positive terminal which hangs over the side of the battery - this causes the 'clearance issues' that some of us have faced. Not all the early TDV8's had them as far as I can tell, so your TD6 is probably OK Thumbs Up
If your positive terminal looks like this
then be prepared to have to 'persuade' the battery into place with pry bars or 'plastic surgery' as the bottom of the charge will foul on the bulkhead. Some have managed to wiggle it in, I went down the route of cutting the plastic retaining lip on the bottom of the opposite side of the battery which gave me the space needed to get the battery further over to the right and give enough clearance to get the positive terminal to seat properly. The picture is taken before the fettling took place as the battery terminal is now a nice snug fit.
Post #169941 4th Feb 2013 10:51am
No problem getting an s5 110A in a td6.
Plenty of room and well worth it. Thumbs Up
Post #169943 4th Feb 2013 10:54am
Googsy's disease is spreading!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #169946 4th Feb 2013 11:11am
Thank you gentlemen.. S5 being ordered.
I always thought I had the explosive charge on mine, but obviously not, as it is nothing like Simons photo. My leads go over the top of the battery. Previously..
Post #169963 4th Feb 2013 12:17pm
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
is this the one that i need, i am pretty sure it is but thought that i would check with you knowledgable gentlemen first.....
http://www.boschcarbatteries.co.uk/index.p...s5015.html
cheers
andy
Post #171626 12th Feb 2013 8:54am
thats the one Andy, type 020, 110amphr,920cca...
the picture is not of the actual item btw.. ... - .- -.
Post #171628 12th Feb 2013 8:57am
According to that they are in preston...
Wonder if they do it cheaper if you pick it up??!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #171632 12th Feb 2013 9:08am
andyleeds
cheers guys, will be getting today!
Post #171634 12th Feb 2013 9:16am
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Just checking but is this battery ok for the 4.4v8 petrol as well? (Yes it's new battery time again) "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #207623 2nd Sep 2013 11:00pm
dirtyharry
Is this not the same battery? I thought Varta made the Bosch batteries, which means this a pretty good deal!
�97.50 delivered! Thumbs Up
http://www.tayna.co.uk/610-200-Varta-Silve...P3200.html Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #207636 3rd Sep 2013 6:35am
it will be ideal Mr P.. Thumbs Up ... - .- -.
Post #207652 3rd Sep 2013 7:56am
Page 1 of 4 1234>
