![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35659 ![]() ![]() |
did you play with the tool whilst the engine was running? ... - .- -.
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 ![]() ![]() ![]() |
Yes I did. I was scared of draining the battery! |
dunno then, hopefully the GAP chaps will let you know.. ... - .- -.
Maybe I should add that after driving again for 10 minutes I had the following faults logged with the IIDTool
ppcsl Member Since: 12 Sep 2012 Location: Ellon, Aberdeenshire Posts: 107 ![]() ![]() ![]() |
Has anyone had any problems with their iiDtool not being seen by the update software or the control software. When I first got it a few months back it connected okay and I was going to check if it needed an update. I have tried it on my PC as well but still the same. Both laptop and PC are running windows 7 one enterprise and the other home premium. I have set the com port to 4 and the laptop sees it just as a USB com port on com 4. The PC sees it as an other device - iiDtool but can't fully load a driver for it.
george, try deleting the updater and app , reboot and then download again.. ... - .- -.
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Yes, I had this problem on xp the other day. The updater said it needed updating and after installing the new version it could not detect the iid tool. I reverted to the previous installation using system restore and everything was fine. I happened to be having an email conversation with gap so I reported it to them and they said they'd look into it. |
Thanks Stan and Ric for your quick replies.
Downloaded the updater again from a link on the forum, uninstalled reinstalled it's working again. As if by magic..... |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Strange issue - since updating my firmware I now ONLY have the Nav On Move option within IID menu.
you installed the wrong firmware, there are two with the 'nav on move' being the second, install the top/first one... ... - .- -.
Yea, just noticed 'Release' and 'Special' and I'm on the latter, flashing now, thanks. |
