Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 28 of 49 <123 ... 272829 ... 474849>
android app here,
https://play.google.com/store/apps/details...&hl=en
it will work on yours if it has bluetooth version 4 or 'bluetooth smart'.... ... - .- -.
Post #248933 18th Mar 2014 9:31am
g4alan
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Baltic Blue
Hi Stan
Thanks for the reply I spent an hour looking earlier but could not find anything its a good job your here looking after all of us Thumbs Up
Alan
Post #248936 18th Mar 2014 9:49am
Thumbs Up ... - .- -.
Post #248937 18th Mar 2014 9:51am
SteveMFr
Site Sponsor
160dmb wrote:
How is progress for the 2010+ version btw?
In stock at Britpart. Call your favorite Britpart dealer and have them ask for part number DA6414 for a 2010-2012 L322 IIDTool (only available in a BT version as the display firmware was not completed to the point where info can be displayed in the cluster - this was only completed for the L405 which has the same hardware. The display will work, but it flickers).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #248967 18th Mar 2014 11:55am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Then it means that this latest version enables me to activate the "timed climate" function on central display (not ordered from the factory) on my 2012 tdv8?
Yes!
Post #248985 18th Mar 2014 2:02pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Hi Guys
When I clear faults with my IID tool, it always seems to clear 31 faults even if there are only a few faults appearing when I scan for faults. Is this normal or is there something not working properly. I did have 31 faults first time I plugged the IID tool in, but that was last year?
Thanks
Andrew 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #249037 18th Mar 2014 6:32pm
PatGAPInnov
Site Sponsor
Hi Andrew
From the user manual:
Clear All
Clears all faults stored in all ECU�s and exits the IIDTool menu. The number displayed when clearing all is not related to the number of fault cleared but to the number of ECU�s on which the faults were cleared.
Cheers
Post #249055 18th Mar 2014 7:09pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Do you know what the Bluetooth setting should be in the CCF file for the Bluetooth to work in the UK. I have an updated B/T module and just want to check that I haven't inadvertently change a setting in the Bluetooth when gong through the menus. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #249191 19th Mar 2014 2:59pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
On a 2004 is there anyway of telling the car to use PAL system like the navcoder?? I know the website site says video soon
Post #249882 22nd Mar 2014 6:32pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Hi, can the IID tool code TPMS sensor serial numbers to the TPMS system? I have a set of summer wheels & tyres about to go on, and understand that as they have their own set of TPMS sensors, they will need coding to the car, and vice versa when the winter wheels/tyres go back on in October.
Fanders
Post #253407 8th Apr 2014 9:34pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Sensors will auto code when fitted and driven - only one that doesnt auto code is spare, and to get around that you just fit it as a road wheel until coded.
Post #253414 8th Apr 2014 10:48pm
mjdronfield
Done a search but can't find anything, and just been on the GAP website to look at the feature list.......
My car doesn't bong to warn me I've left the lights on when I get out.
Can this be enabled with the iidtool ?
could have sworn it used to do it........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #253528 9th Apr 2014 2:37pm
is that when your switch is on 'side' or 'headlight' ?
...and have you got 'follow me home' [FMH] switched on, maybe that cancels the bong. ... - .- -.
Post #253530 9th Apr 2014 2:50pm
mjdronfield
Sorry, yes Stan.
Light On is shown on the instrument cluster.
Will double check in case it's me having a senior moment, or the music on too loud in the car......
It does have the follow me home feature.
Will check to make sure the problem is not located in the drivers seat Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #253532 9th Apr 2014 2:54pm
mjdronfield
Remembered to check yesterday, can't get Light On to show on the instrument cluster, let alone the bong. It just puts the "follow me home" lights on and Headlight Delay on the dash when I get bored and turn of the lights after turning the engine off.
I know its supposed to have that feature,
Will check the manual as it could be good old human error, and be off topic. Soz ! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #255683 23rd Apr 2014 10:05am
