Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 29 of 49 <123 ... 282930 ... 474849>
gav
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Just got my IIDTool from Dan yesterday for my 53 4.4 vogue.
A long list of faults cleared no problem.
Now my question may be simple and already discussed but I couldnt dig anything up searching.
Am I right in thinking the air suspension goes up and down after clearing faults?
When mine did this I immediately got the HDC inactive and Air susp inactive bongs/ messages that then disappeared on restarting the car. Is this normal?
Post #256178 25th Apr 2014 7:28pm
did you play with the tool whilst the engine was running? ... - .- -.
Post #256180 25th Apr 2014 7:29pm
gav
Yes I did. I was scared of draining the battery!
Post #256185 25th Apr 2014 7:32pm
dunno then, hopefully the GAP chaps will let you know.. ... - .- -.
Post #256186 25th Apr 2014 7:33pm
gav
Maybe I should add that after driving again for 10 minutes I had the following faults logged with the IIDTool
32 CAN bus fault
57 air susp inact
23 key 0 random code tolerance increased
Post #256190 25th Apr 2014 7:37pm
ppcsl
Scotland 2005 Range Rover Autobiography Td6 Java Black
IIDtool not connecting to laptop or PC
Has anyone had any problems with their iiDtool not being seen by the update software or the control software. When I first got it a few months back it connected okay and I was going to check if it needed an update. I have tried it on my PC as well but still the same. Both laptop and PC are running windows 7 one enterprise and the other home premium. I have set the com port to 4 and the laptop sees it just as a USB com port on com 4. The PC sees it as an other device - iiDtool but can't fully load a driver for it.
Is there a driver downloadable for this? Windows 7 is usually pretty good at grabbing a working driver for just about anything you throw at it.
George Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #266934 23rd Jun 2014 6:45pm
george, try deleting the updater and app , reboot and then download again.. ... - .- -.
Post #266944 23rd Jun 2014 7:42pm
ric355
Re: IIDtool not connecting to laptop or PC
Yes, I had this problem on xp the other day. The updater said it needed updating and after installing the new version it could not detect the iid tool. I reverted to the previous installation using system restore and everything was fine. I happened to be having an email conversation with gap so I reported it to them and they said they'd look into it.
Post #266969 23rd Jun 2014 9:21pm
ppcsl
Thanks Stan and Ric for your quick replies.
I had initially tried it on the original updater and controller software and it didn't work so I downloaded the newer software and still nothing. I also did a clean install onto a PC which didn't have it on before and it was the same.
Post #266996 23rd Jun 2014 10:37pm
ppcsl
Downloaded the updater again from a link on the forum, uninstalled reinstalled it's working again. As if by magic..... Laughing Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #267197 24th Jun 2014 11:17pm
Thumbs Up ... - .- -.
Post #267212 25th Jun 2014 7:16am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Strange issue - since updating my firmware I now ONLY have the Nav On Move option within IID menu.
Gonna try reinstalling firmware.
Post #268818 3rd Jul 2014 10:01am
you installed the wrong firmware, there are two with the 'nav on move' being the second, install the top/first one... ... - .- -.
Post #268824 3rd Jul 2014 10:17am
Katash
Yea, just noticed 'Release' and 'Special' and I'm on the latter, flashing now, thanks.
Post #268827 3rd Jul 2014 10:30am
Post #268833 3rd Jul 2014 10:44am
