![]() | Home > Technical (L322) > "rear water ingress" |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Your hammer obviously want big enough or you wern't hitting said problem hard enough. These are typical SBE's! |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Guys this could be good news as my boot well was swimming aftre the rain today, jusdt dried out what i could and then have sealed mine armatures with good old vaseline so am hopeful that this is the problem in that area. Will let you know how it goes
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
excellent work guys |
Hi SC yes i have checked the seal and seems to be ok, the water seems to be coming from inside the metal boxsection which is what makes me think that the hinge area is the problem as these bolt through into it as there is no access to to the bolts inside any where, i wonder if there is a gasket under the hinges as well!!??? Oh well have to get the vaseline out again, car bwill be held together with it soon. My next RR i will ask LR to put a jar in the boot for free !! |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Interesting - I had some leaks in the boot before I took off the armatures and replaced with towbar armatures - but as part of that work, I did add some silicone to the neaprene seal between the armature and the body as a "just in case" measure and have now not had any leaks since ... |
*****UPDATE*****
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2052 ![]() ![]() |
I have a LR Fixed plate towbar for sale if interested |
Well some fairly heavy rain today and a quick check tonight found my boot nice and dry with no water ingress.....phewww |
Hi CG,
Hi RR8701......I have to say that I failed with the pics as I did it at my mates garage and had forgotten my camera and phone......
