![]() | Home > Technical (L322) > "rear water ingress" |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Waiiitttt a minue rob. Lol. What is an armature? When I do that to my bottom tailgate it is wet like urs too but I diddnt make much of it. Where are u intending to put on the seal. Will u be taking the bumper off to do this |
My understanding of armature is the big metal frame that sites behind the bumper. There is one front and rear. Now what can be seen in my pics might not be the armature ebut whatever it is I would guess that's the cause of the leak. I will just put the silicon/vasoline on without removing the bumper first as I don't know how labour intensive it is to remove. I will just be heavy handed with the goo and make a bloody big seal. If the water stops getting in the boot I will take the bumper off in the spring and do a proper job. From looking at mine there seams to be a rubber gasket or such between the body and black bit. I would guess that's split or perished and causing the leak. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I still think you will get a better seal tackling the bolt nuts on the inside.
Hi CG,
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I've checked the RHS cubby hole and mine is dry in there.....mine is leaking only on the LHS.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi whats the part number for the gasket, been to the dealer and was told there is no gasket V8 facelift Range Rover Autobiography 22" wheels.
I couldn't find a part number either, but if you look at the fitting instructions for the towbar armature it clearly shows that there is a gasket to be fitted.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Maybe worth contacting westfalia as they come with the kit.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Not sure what the original gasket is made from but I'm sure this company will be able to advise |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
I have today had the man from Tracker out to replace a sensor and he said that i had a water leak, it is coming down the right rear pillar in the boot. he fisrt thought that it was coming through the rubber gaitor that passes the cables to the top part of the rear tailgate but when he took the headlining out it was all dry. He seems to think it is coming in through the area where the tailgate bolts are and then tracks down the box section coming through a join. When he took of the trim panel where the speaker is it was soaking wet and now that panel is off i can see where is coming out but still cannot see how it is getting in.
Hi All,
UPDATE:
Hi CG,
