![]() | Home > Technical (L322) > "rear water ingress" |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
No but it's just a piece of foam, easy enough to make one |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Mine doesn't have a tow bar so it must be coming in somewhere else! The rear bumper attachment bolts sounds about right. The only place water is coming in from is the rear right had of the boot. |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Hi DophinBoy,
Hi Guys, any more update on this at all ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
re spray foam, it repels water very well and when solid is easy to cut and shape.. |
Scarey if I was to spray the foam into the two holes in the below pic and also that area would it block any known passage ways
it's the hole BELOW the lower bolt where the water comes in. block that. AFAIK the 2 big holes are not part of the problem. |
Hi Guys, thanks for that, ill dry out and try block tonight as the RR has decided to give itself an added option of a paddling pool again.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I've still got the problem - been trying like mad to find the cause - I've ordered a new boot seal in the hope that's the problem but not so sure.
anyone got any good idea of what sealant to use in blocking this gap ??? dont think the foam stuff is going to be so great if its always going to be wet on otherwise ???
I think if you block that hole all that will happen is the water will collect behind the panel until the level is such that it overflows from the circular holes next to the bumper bolts.
I dont understand why it would collect behind there tbh. I am trying to understand how the water gets to that area in the first place. where does this water come from ????
well i had a bit of a break through. i done the tissue tissue in each corner and it looks like the right hand side corner (fuse compartment side) seems to leak from the hole in the corner. this was at standstill as well while it was raining last night.
Just checked mine again and I have the exactly the same issue - I am waiting on a new seal to arrive and will report back on whether that cures it or not........ Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
