![]() | Home > Technical (L322) > "rear water ingress" |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
bad luck matt, it is fairly common and you need a water shedder and probably a new unit.
Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70 ![]() ![]() ![]() |
Thanks again scarey. So where exactly is the moisture coming from? And does the water shedder protect the entire area? I had thought maybe the dealer had been less than careful when washing or shampooing but I guess not. Is it from underneath or around the light housing or something? |
not had the problem matt so i've not investigated it...i'm sure someone will come along soon and help. ... - .- -.
kanajobe Member Since: 12 Jun 2011 Location: Bristol Posts: 8 ![]() ![]() ![]() |
Hi,
Ok so update. Navigation unit is ruined as expected. The garage think they have found a couple of issues where the water came from. Upon research it often happens to vehicles with sun roofs and we had a slightly perished boot seal which is being replaced. Something for others to check with the same issue |
could it also be a blocked drainage pipe from the sunroof.. ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
When I had my TD6 and noticed the rear washer was not operating correctly, it was sending washer water down the inside of the rear glass, this then collected in the trim, and no doubt made its way down into the inside of the car, luckily I caught this very early and no damage was done, but this is another way water can get into the car. Discovery 4 HSE
Great info many thanks. I will be checking this also |
I would also consider whether part of the problem could be condensation.
you could keep the a/c on all the time, that'll keep the air dry.. ... - .- -.
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 ![]() ![]() ![]() |
I'm getting a bit jumpy over these rear water ingress problems as there doesn't seem to be a single cause.
