![]() | Home > General > pre heater question |
tried mine yesterday, 20 minutes and the cabin was roasting hot |
What caused those faults though simon as faults dont often come up on their own?
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Kingpleb, on my RRS it was failed starts that knackered it. I think if it fails to start 3 times in a row then you will need to clear the ecu in order for it to work again. Come to think of it I believe that we also replaced some fuel line to the FBH to prevent it happening again. The FBH in the RRS is essentially the same unit as in the FFRR but without the timers and remote (in some cases). Mine was a 55 plate and the FBH only came on with the engine and then only when the ambient temperature was less than 4 degrees. When it was really cold last winter the FBH was running constantly to supply enough heat for the demands the HVAC was putting in just to keep my lardy arse warm... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
I've now done more testing and can confirm that the remote starts the fans OK but the FBH doesn't fire up. The fans then run for a few mins and stop, presumably because the FBH isn't getting warm.
On my TD6, computer screen the general menu screen only shows Aux. Ventilation, no reference to Aux. Heating.
Graham, I believe that you can 'force' a start cycle by putting 12v across a couple of the pins in the connector to the FBH.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
The LR spec FBH's can't be run manually by applying 12V or ground to a control pin, they would require a chat to a controller or diagnostic package over WBUS (Webasto Bus).
Yes, I have a D3 as well, so the side by side comparison is possible... I couldn't find the FBH on the FFRR.
Wasn't necessarily directed at your questions |
Yeah, no prob. Graham
Graham
That's gotta be worth a try. Give me an hour. Graham
The wiki also suggested trying removing the plug on the heater if the fuse alone did not work. Bring as we are both clueless as to where th FBH actually is located the fuse will have to do |
Right, fuse out and car asleep for a couple of hours. Fuse back in. Slept again.
