![]() | Home > General > What Did You Do In Your Full Fat Today |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Clicked over 100,000 miles today in my MY2012 - 40,000 of which are mine and I’ve enjoyed every one of them. |
Proftinkerpot Member Since: 23 Dec 2022 Location: County Antrim Posts: 198 ![]() ![]() ![]() |
I had my oil leak sorted along with a few other issues. My leak was the oil cooler so it was replaced. The coolant reservoir was flushed but for some reason the float wouldn't do what it was born to do. I wasn't going to live with a constant low coolant warning so I asked the garage to just change it too.
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 183 ![]() ![]() ![]() |
Picked up the car after 2 weeks in the garage whilst I was on hols. They’d wire brushed the whole of the underside where there was any rust and then applied Fertan rust converter. Once cured the whole of the underside was sprayed with Dynax UC in 2 coats. Dynax S50 was applied liberally into any cavity, including subframes and sills. This is one Rangey that isn’t going to go rusty !
Swapped out the rotary gear selector surround trim for a new item. It’s the large aluminium coloured bit and it was pitted and marked from 1000+ careless dropping of keys into the central cup holder area.
knotty68 Member Since: 31 Mar 2025 Location: Warwickshire Posts: 4 ![]() ![]() ![]() |
New wipers front and rear.
Sewed on a surprisingly acceptable Aliexpress steering wheel cover which was tedious, but satisfying.
Drove to four different locksmiths to get a couple of blanks cut for key fob upgrade.
