Home > Technical (L405) > L405 Grinding/Rumbling Noise at Rear When Pulling Away
Stuart-
Here's a funny one.
This only happens occasionally, mostly on one bit of road on a slight incline, when pulling away from a junction.
I hear a small grinding or rumbling noise from the back somewhere. It sounds almost like something rolling around on the boot floor, but there is nothing. I notice it most days at one specific junction near work. I stop at the junction, and as I gently pull away, I hear the noise.
I get it now and again elsewhere. But it's mainly at the one place.
Now that is not as daft as it sounds. I had a knocking noise a few months ago that sounded like a bush worn somewhere. The main dealer couldn't find it and inferred it was in my head. In the end, I took a mechanic out to the only bit of bumpy road I knew I could replicate it, and we all heard it. They found it and fixed it.
I am thinking of something driveshaft or propshaft related. Like a joint has play and only rumbles in certain situations. I wondered if this was something anyone else has encountered and if anyone might be able to speculate what it might be? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #708792 10th Jan 2025 1:40pm
mpirie
Do a search for transfer box issues/servicing.
I believe replacing the fluid and resetting the clutches resolves it.
Mike
Post #708794 10th Jan 2025 1:47pm
Stuart-
I just found a topic on it that described it as a judder, that's a fair description. The topic said "Transfer box - every 5 years or 60k miles, whichever is first" - mine has done 65k, so it must be due. Assuming never done.
Is this something I could get under warranty I wonder, or is it regarded as a service item? 2017 4.4 SDV8 Autobiography in black
Post #708795 10th Jan 2025 1:53pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I have something similar, it's an occasional thump which I thought was coming from rear diff.
Had it in for a look, diff apparently ok , no apparent issues there, however all 4 ARC bushes are shot, they reckon the noise is them moving about under certain load.
Getting all 4 replaced early next month, will report back.
Post #708804 10th Jan 2025 4:47pm
Stuart-
I have had the transfer box oil changed and it is still the same.
How are the clutches reset? Is that something an indy would routinely do when that oil is changed? 2017 4.4 SDV8 Autobiography in black
Post #713709 10th Mar 2025 2:34pm
Stuart-
I asked the indy about resetting clutches, he said it isn't really a thing they do as the clutches learn ongoing. He also said if you do it, the car will drive terribly until it relearns and is unlikely to be any better.
Can anyone opine if that is true?
It's been a couple of weeks now since the transfer box oil was changed. They did say the oil was a bit manky that came out. So any relearning will have happened by now. And it's still doing it. They had it in again today and they couldn't replicate it they said. 2017 4.4 SDV8 Autobiography in black
Post #714513 20th Mar 2025 7:40pm
GraemeS
Australia
Calibrating the e-diff won't induce any harshness and is not something that the e-fiff learns over time. There is a single, multi-plate clutch that needs to be correctly calibrated. The plates wear over time so recalibration is required for it to operate correctly. L405 D350 SE Carpathian Grey D5 19" rims
Post #714526 20th Mar 2025 9:06pm
Stuart-
And is this something done by just plugging it in?
This coupled with my step calibration issue in another topic is leading me to think my indy just doesn't have the correct software for L405s. 2017 4.4 SDV8 Autobiography in black
Post #714565 21st Mar 2025 12:25pm
D3Jon
OP is discussing the Transfer Box adaptations.
When you say e-diff are you talking about the rear diff Graeme?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #714573 21st Mar 2025 4:08pm
D3Jon
Transfer box adaptions (or clutch re-learning) can be reset with appropriate diagnostic gear, for example the GAP IID can do this. Any half decent LR Indy will have a tool which can re-learn the transfer box adaptions on your L405.
Whether it should be done or not is another question. I'd listen to your Indy if they recommend leaving alone.
2014 Disco 4 HSE
Post #714574 21st Mar 2025 4:11pm
GraemeS
Australia
The rear e-diff calibration is the same type of process as the transfer case centre diff calibration, initiated by the diagnostic tool issuing the appropriate command. Gap added the function to the L322's options when I replaced my L322's open diff with an e-diff. L405 D350 SE Carpathian Grey D5 19" rims
Post #714582 21st Mar 2025 8:38pm
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
I also have that noise when moving off, nearly all the time. Just like something rolling around. Never hear it when on the move. Its driving me mad. Mileage about 28000 Big Cry
Post #714592 21st Mar 2025 10:35pm
GraemeS
Australia
To be clear, it is the gearbox that adapts its clutches, not the transfer case nor the e-diff. The transfer case calibration also calibrates the range shift motor.
If gearbox adaptations are reset then the gearbox re-learn procedure should be followed to re-learn clutch settings quickly to avoid possible harsh changes that can occur whilst the gearbox slowly adapts. L405 D350 SE Carpathian Grey D5 19" rims
Post #714596 22nd Mar 2025 1:17am
D3Jon
There is a calibration process for the Transfer Case which measures the clutch calibration angles and adapts accordingly.
This is separate to the high-low range adaption. So it can be done.
2014 Disco 4 HSE
Post #714607 22nd Mar 2025 10:49am
D3Jon
See here for example:
https://www.fullfatrr.com/forum/post687085.html
2014 Disco 4 HSE
Post #714608 22nd Mar 2025 10:51am
