![]() | Home > Technical (L405) > L405 Grinding/Rumbling Noise at Rear When Pulling Away |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 369 ![]() ![]() ![]() |
Here's a funny one.
I just found a topic on it that described it as a judder, that's a fair description. The topic said "Transfer box - every 5 years or 60k miles, whichever is first" - mine has done 65k, so it must be due. Assuming never done.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2686 ![]() ![]() ![]() |
I have something similar, it's an occasional thump which I thought was coming from rear diff.
I have had the transfer box oil changed and it is still the same.
I asked the indy about resetting clutches, he said it isn't really a thing they do as the clutches learn ongoing. He also said if you do it, the car will drive terribly until it relearns and is unlikely to be any better.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2654 ![]() ![]() |
Calibrating the e-diff won't induce any harshness and is not something that the e-fiff learns over time. There is a single, multi-plate clutch that needs to be correctly calibrated. The plates wear over time so recalibration is required for it to operate correctly. D350 SE Carpathian Grey D5 19" rims |
And is this something done by just plugging it in?
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 519 ![]() ![]() |
OP is discussing the Transfer Box adaptations. When you say e-diff are you talking about the rear diff Graeme? Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Transfer box adaptions (or clutch re-learning) can be reset with appropriate diagnostic gear, for example the GAP IID can do this. Any half decent LR Indy will have a tool which can re-learn the transfer box adaptions on your L405. Whether it should be done or not is another question. I'd listen to your Indy if they recommend leaving alone. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
The rear e-diff calibration is the same type of process as the transfer case centre diff calibration, initiated by the diagnostic tool issuing the appropriate command. Gap added the function to the L322's options when I replaced my L322's open diff with an e-diff. D350 SE Carpathian Grey D5 19" rims |
chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 108 ![]() ![]() ![]() |
I also have that noise when moving off, nearly all the time. Just like something rolling around. Never hear it when on the move. Its driving me mad. Mileage about 28000 |
To be clear, it is the gearbox that adapts its clutches, not the transfer case nor the e-diff. The transfer case calibration also calibrates the range shift motor.
There is a calibration process for the Transfer Case which measures the clutch calibration angles and adapts accordingly.
See here for example:
