Home > Technical (L405) > L405 Grinding/Rumbling Noise at Rear When Pulling Away
Stuart-
Here's a funny one.
This only happens occasionally, mostly on one bit of road on a slight incline, when pulling away from a junction.
I hear a small grinding or rumbling noise from the back somewhere. It sounds almost like something rolling around on the boot floor, but there is nothing. I notice it most days at one specific junction near work. I stop at the junction, and as I gently pull away, I hear the noise.
I get it now and again elsewhere. But it's mainly at the one place.
Now that is not as daft as it sounds. I had a knocking noise a few months ago that sounded like a bush worn somewhere. The main dealer couldn't find it and inferred it was in my head. In the end, I took a mechanic out to the only bit of bumpy road I knew I could replicate it, and we all heard it. They found it and fixed it.
I am thinking of something driveshaft or propshaft related. Like a joint has play and only rumbles in certain situations. I wondered if this was something anyone else has encountered and if anyone might be able to speculate what it might be? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #708792 10th Jan 2025 12:40pm
mpirie
Do a search for transfer box issues/servicing.
I believe replacing the fluid and resetting the clutches resolves it.
Mike
Post #708794 10th Jan 2025 12:47pm
Stuart-
I just found a topic on it that described it as a judder, that's a fair description. The topic said "Transfer box - every 5 years or 60k miles, whichever is first" - mine has done 65k, so it must be due. Assuming never done.
Is this something I could get under warranty I wonder, or is it regarded as a service item? 2017 4.4 SDV8 Autobiography in black
Post #708795 10th Jan 2025 12:53pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I have something similar, it's an occasional thump which I thought was coming from rear diff.
Had it in for a look, diff apparently ok , no apparent issues there, however all 4 ARC bushes are shot, they reckon the noise is them moving about under certain load.
Getting all 4 replaced early next month, will report back.
Post #708804 10th Jan 2025 3:47pm
