Home > General > What Did You Do In Your Full Fat Today
Page 380 of 380 <123 ... 378379380
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Today I have been mostly...
Changing the rear hatch struts.
Changed the non functioning high level brake light. It was so sun scorched it looked like it had been sand papered.
Swapped over the start stop switch. The replacement had a silver bezel, so had to gut the new one just for the push button bit, but all good and matches the glove box switch bezel.
Removed the ugly front window wind deflectors.
They're such easy cars to work on for minor incidentals like these. No wonder those us who can do a bit of spannering love them.
You wouldn't get this much satisfaction from a Tesla.
Post #713494 7th Mar 2025 4:00pm
JimFos
Went to get the car out for a big shop of animal feed and found it had a flat. B****y hell. Pumped it up and rolled it out of the way to reach my lightweight to take instead. More practical vehicle for the task as took nearly double usual amount of feed, though being so loaded the return journey wasn't as serene as the ff would have been. Once at home and unloaded took wheel off ff and found it has double puncture. Grrr. Other tyres all look clear...Hoping they're pluggable.....
Post #713578 8th Mar 2025 4:35pm
JonnyCJ
Spent a couple of hours taking out the air boxes, cleaning them inside and out, cleaning the MAF sensors and fitting a new filter. Nr1 wasn’t too bad to be honest and nr2 filter was as expected, virtually pristine, so popped that in nr1 and the new filter in Nr 2.
Also went to change the pollen filter and that was virtually new, so popped it back in and put the new one on the shelf with the spare air filter.
Whilst the air boxes were out I put some Fetran rust converter on a few little areas that were showing slight signs of rust. Mainly the relay bracket and the area under Nr 1 filter box. I was actually quite impressed at how little rust there was in the engine bay.
Tomorrow I’ll be sucking the oil out, replacing it and sticking in a new filter and then on Thursday it’s off to the Indy to get all the transmission fluids changed and a good old check over.
Still lots to do including ordering new screws for the air boxes.
Post #713586 8th Mar 2025 6:04pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Fixed the passenger door which would not open from the outside. Fitted a new cable.
If you want some details see My Range Rover https://www.fullfatrr.com/forum/topic55392-105.html
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #713598 8th Mar 2025 7:47pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Headed for the Alps. 455 miles from home to the overnight stop at Besancon. Computer says average 26 mpg. Full tank when I left and a range of 32 miles when I pulled up…..
Gratuitous pic of the mighty beast at the old Reims circuit pits
Tomorrow i head for Crans Montana, so up over the Jura and then down to Lausanne , following the Rhone Valley. Trips like this are why I have a FFRR 2024 - 2021MY L405 5.0 SC Portofino Blue
2018 - 2024 2016MY L405 4.4 SDV8 VSE Aintree Green
2017 - 2018 2017MY Jaguar F Pace Portfolio 3.0 SDV6 BRG
2013 - 2017 2010MY L322 3.6TDV8 VSE Buckingham Blue
Various RR Sports and Freelanders before that!
Post #713612 8th Mar 2025 10:00pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Fitted new brake pads front and rear.
Rears weren't too difficult. One piston a bit difficult to wind back. The pads on that side were more worn than the other side.
The fronts seemed to be going ok... I know, thanks to the wisdom of others on this forum, that the Brembos can be challenging. Then, at the last pin (the centre pin on the drivers side) it was stuck fast. Having seen that others had cut the pin to remove the two halves separately I resorted to that, and it still took an awful lot of hammering but eventually it came out. I don't think I would have had the confidence to do it if I hadn't seen others do it, so I owe the forum a pint!
Changed the bleed nipples too, as they all looked manky. And the wheel cap centres too.
Took me all day, but as an amateur I'm really quite pleased with myself! I think I spend more time working on this car than I spend driving it!
Post #713668 10th Mar 2025 12:14am
JonnyCJ
Didn’t get round to changing the oil yesterday as the battery was too weak to start the car. A new battery should have been delivered last Thursday and finally arrived today. Got home from work and did some preliminary dismantling ahead of the swap over tomorrow - hooray for WFH.
Used the T30H Torx for the ECU security plate and yes, I had to buy the Laser 5301 security Torx set just to get that one Torx. The plate was showing some light signs of surface rust, so being a bit OCD I sanded, primed and satin blacked it, so it’ll look nice when it goes back in.
I do love little jobs like this.
Also dropped in to see my paint guy on the way home from work and he got underneath and had a look at the jacking points and sills. He popped back up with the comment that it wasn’t actually that bad and didn’t need any major surgery. He does at least 1 Fatty a month and has done for many years, so happy to trust his judgement.
Post #713724 10th Mar 2025 7:27pm
JonnyCJ
Today’s little jobs were replacing the bonnet struts and putting the new battery in. Also cleaned up the screen on the new dual view display unit which arrived today.
Decided to replace the blower motor whilst the dash top is off, so ordered a new Nissens unit- it’s mildly noisy, but not unobtrusive, but for the cost of a new one, it’s good for peace of mind.
Post #713834 11th Mar 2025 8:30pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Replaced a further 4 swollen SS wheel nuts, no external signs of swelling or damage, just can't get the socket on them, luckily bought 10 in advance.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #713954 13th Mar 2025 9:40am
AndyRoo
Lightly wirebrushed and repainted the rear arch leading edges in Kurust to protect them as looks like a bit of surface rust where the underseal had worn off.
Once dried liberally painted over with 2 coats of Nitromoors Smooth Metal Finish to protect against further wear.
It looks like with the constant opening and closing of the rear doors the seal has been rubbing off the underseal protection I put on last time so replaced that with something more hardwearing.
Glad I discarded the Freelander trims so if it comes back I can see clearly.
Also replaced rear discs, pads and wear sensor.
Post #714032 14th Mar 2025 2:22pm
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Drove around in Sport mode for a bit, highly entertaining. Very Happy Very Happy
Post #714054 14th Mar 2025 6:15pm
