![]() | Home > My Range Rover > 5 RRs and I have to give up |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2638 ![]() ![]() |
Jacking by either front suspension arm isn't kind to the ball-joints because they aren't designed to take weight pushing the ball into its cup. Steering forces are basically horizontal and much less because the wheel moves. I'll jack the rear under the wishbones because of the type of bush, but not the front.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 719 ![]() ![]() |
Could be Knares, I'm not sure if it's lubricated by the power steering fluid or if it's greased somewhere internally. |
Regards internal leakage knares I was able to check this during my power steering pressure test.
Booked in for an alignment check today.
Alignment results are in.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 780 ![]() ![]() ![]() |
i have no idea
The before is 'before adjustments' and the current should be read as 'after adjustments' but no adjustments could be made at the time due to seized rusty components.
Good spot Knares, I have no idea why. I'll have to ask that question! |
Seized track rod ends are more likely the cause than the toe-in but everything counts. |
I've had both track rod end balljoints disconnected from the wheel knuckles Graeme and they articulate by hand so not sure its that.
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 13 ![]() ![]() ![]() |
the toe-in is a disaster.
Do you think this could be the cause of my heavy steering then RRfranz? Way too much toe in?
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 704 ![]() ![]() ![]() |
Lewis,
