![]() | Home > General > What Did You Do In Your Full Fat Today |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 115 ![]() ![]() ![]() |
Today I checked the auxiliary battery. Didnโt have to remove it completely to see the manufacture date stamped on the negative terminal: Week 47 Year 12! ๐ฎ
Caveman2000 Member Since: 11 Jan 2023 Location: Lincolnshire Posts: 1 ![]() ![]() ![]() |
I replaced my near side parking brake actuator! |
DesertGSD Member Since: 18 Dec 2024 Location: DXB Posts: 14 ![]() ![]() ![]() |
Plan on using the FFRR more this year so got her some new tints and a bath, will be sending her in for a proper multistage detail before summer starts
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
What did I do this weekend?
New engine mounts and fresh oil change. Had some jerking issues which I assumed was the transfer case but turned out my engine mounts were shot, all fixed and smoothness is restored.
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 150 ![]() ![]() ![]() |
I have installed a 1500W inverter so that I can have a coffee on my trips to Andalusia. The Nespresso machine draws 1250W, so there is enough power available.
After an unsuccessful attempt yesterday to diagnose why my rear wash doesn't work (probably pumping screen wash into the cabin somewhere), and an unsuccessful attempt to swap the FBH with a replacement, today I have successfully changed the rear diff oil. Nice to actually achieve something! |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Replaced both external mirror glasses back to tints as one heater had failed.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
Passed the MOT |
Stripped & serviced the suspension air compressor, Hitachi, replaced the piston rings & seals. Old one was not too worn, but thought I'd do as a precausionary measure as I had some spare time.
After recently passing the MOT, driving home yesterday lost all the air and had to crawl home through town with the car on the bump stops - not a nice experience, eventually found the leak on the front offside air bag. So ordered two new complete struts / bags as the car is 07 reg, been squirting penetrating oil EVERYWHERE, in preparation of removing the old struts on Monday, bad news with the weather though, looks like it will be a cold, wet and windy job |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
I replaced the wiper blades and god damn does it feel nice to have a clean screen Its actually a sport |
Got around to fitting the replacement suspension relay from PowerfulUK as a preventive measure.
chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 105 ![]() ![]() ![]() |
Not very exciting, but ordered some Gtechniq L1 leather protector. Gave the seats a shampoo this morning as I like them protected. Found some L1 in the garage, but it was finished |
