Home > Technical (L322) > L322 2011 Reverse Camera and Parking Radar questions |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35450 |
i think the FF camera is NTSC [?]..can you select that in the android menu. ... - .- -.
9th Jan 2025 8:44pm |
Acecross Member Since: 29 Apr 2024 Location: Torquay Posts: 4 |
There isn’t an option for NTSC - not that I’ve found yet anyway.
9th Jan 2025 9:01pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2550 |
It appears that AHD can use NTSC signals so try AHD. |
10th Jan 2025 1:48am |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 |
Hi Acecross.
10th Jan 2025 9:18am |
There is one power cable and one optical cable that you have to disconnect in the passenger footwell and a new cable goes from the new head unit to these cables - the cable on the head unit is longer so it isn’t a problem. All the other cables are behind the head unit. It’s not too complicated. It sounds really good - I’m really very happy with it. |
10th Jan 2025 10:52pm |
Thank you very much for that. It sounds very good.
11th Jan 2025 4:56pm |
Yes you can fit the side trims. It fits in the factory radio ‘cradle’. The grey of the radio surround on the new unit is perhaps a little more shiny than if it were a perfect match but it’s pretty good.
11th Jan 2025 10:04pm |
Thanks again.
12th Jan 2025 12:02am |
