![]() | Home > Technical (L322) > L322 2011 Reverse Camera and Parking Radar questions |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
i think the FF camera is NTSC [?]..can you select that in the android menu. ... - .- -.
Acecross Member Since: 29 Apr 2024 Location: Torquay Posts: 4 ![]() ![]() |
There isn’t an option for NTSC - not that I’ve found yet anyway.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
It appears that AHD can use NTSC signals so try AHD. |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
Hi Acecross.
There is one power cable and one optical cable that you have to disconnect in the passenger footwell and a new cable goes from the new head unit to these cables - the cable on the head unit is longer so it isn’t a problem. All the other cables are behind the head unit. It’s not too complicated. It sounds really good - I’m really very happy with it. |
Thank you very much for that. It sounds very good.
Yes you can fit the side trims. It fits in the factory radio ‘cradle’. The grey of the radio surround on the new unit is perhaps a little more shiny than if it were a perfect match but it’s pretty good.
Thanks again.
