Home > Technical (L322) > L322 2011 Reverse Camera and Parking Radar questions
Acecross
2012 Range Rover Westminster TDV8 Santorini Black
Hi All.
First post so go easy on me! Very Happy
I have just replaced the factory head unit in my 2011 L322 with an android unit from China. The unit itself was pretty much plug and play and is working mostly as expected and I’m very happy with it for the price. It maintains the 4x4 info and the steering wheel controls work.
My car has the Logic7HD set up and the factory surround camera system - I expected only the rear camera to work which is the case.
My question relates to the camera/radar. When the reverse camera is active I still get the factory reverse lines and the proximity/radar sensors which is good but I also get the back and nav buttons and a “touch image for further options” button which obviously doesn’t do anything now and looks a bit out of place. What I’d like to know is what is adding those buttons and is there a way to disable them - I assume it’s not built into the camera image? Is there a module? Can this be coded out with the Gap tool?
The factory reverse camera isn’t great quality - I’m not sure if it’s worse than it should be - I have considered replacing it but it doesn’t seem possible to get a new upgraded plug and play unit. If I do go for an aftermarket unit and make it work would I be able to keep the factory radar and reversing lines? Or if I get a new camera is there a way to make the factory parking sensor/radar talk to the android head unit - it has the option to show its own radar overlay with an image of a car but it doesn’t show any activity at the moment.
Any advice or experience would be appreciated.
Thanks
Acecross
Post #708741 9th Jan 2025 8:24pm
i think the FF camera is NTSC [?]..can you select that in the android menu. ... - .- -.
Post #708745 9th Jan 2025 8:44pm
Acecross
There isn’t an option for NTSC - not that I’ve found yet anyway.
There is an option to switch from TV1 to AHD - I assume this is for a more modern camera.
Post #708746 9th Jan 2025 9:01pm
GraemeS
It appears that AHD can use NTSC signals so try AHD.
Post #708761 10th Jan 2025 1:48am
madnessgonemad
Hi Acecross.
I too have the HD audio system. Did you have any problems with the connections? Are all the connections to the new unit in the dash or did you have to run cables anywhere else?
Thanks
Post #708772 10th Jan 2025 9:18am
Acecross
There is one power cable and one optical cable that you have to disconnect in the passenger footwell and a new cable goes from the new head unit to these cables - the cable on the head unit is longer so it isn’t a problem. All the other cables are behind the head unit. It’s not too complicated. It sounds really good - I’m really very happy with it.
Post #708829 10th Jan 2025 10:52pm
madnessgonemad
Thank you very much for that. It sounds very good.
One final question; can you fit the side trims from the original head unit to the new one for that OEM look?
And, I take it that you bought your unit from Ali Express?
I’ll shut up now!
Post #708869 11th Jan 2025 4:56pm
Acecross
Yes you can fit the side trims. It fits in the factory radio ‘cradle’. The grey of the radio surround on the new unit is perhaps a little more shiny than if it were a perfect match but it’s pretty good.
Yes I got it from Ali Express. If you want a link then happy to drop you a message. I have no vested interest - it was just the one with the most convincing sales page!
If anyone can answer my questions above it would be appreciated ☺️
Post #708899 11th Jan 2025 10:04pm
madnessgonemad
Thanks again.
A link would be very useful.
I hope someone comes along with an answer to your question.
Cheers!
Post #708904 12th Jan 2025 12:02am
