Home > General > What Did You Do In Your Full Fat Today
Page 377 of 382 <123 ... 376377378 ... 380381382>
Weegie
Passed MoT . No advisories. Thumbs Up John
GAP iiD BT-Sold
Post #706085 4th Dec 2024 2:48pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Had a new rear caliper fitted, no more hot wheels.
Post #706284 6th Dec 2024 6:09pm
AlexTVR
Following tips from a post in ffrr fitted new B pillar trims today, replacing bubbling paint of original ones. Originals were letting sides down after having rear arches replaced and painted recently.
 2010 Supercharged
Post #707190 18th Dec 2024 2:27pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
I took the car for an MOT. I was kind of dreading what might fail on, as it’s 11 years old, and this is the first MOT since i bought it. I got the “Suspension fault. Vehicle may lean when cornering” message on the way to the MOT. But it passed, with a minor and some advisories. Very Happy
Post #707496 23rd Dec 2024 2:39pm
Barmybrummie
Took it to Kwik fit in Abergavenny this morning to have a hunter wheel alignment. It was way out, steering feels much better and no more wheel rumble. 2 new tyres needed now though.
Post #707676 27th Dec 2024 2:37pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Fitted paddle shifters today & all done & dusted in 2 hours. It works a treat & great to help slow the car down.
Also fitted new offside front brake pipe as the old was a little corroded & the MOT is due soon. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #708055 1st Jan 2025 11:17pm
AlexTVR
Checked heated element of new screen fitted during summer actually worked - It did 😁, at least Autoglass got one thing right…. 2010 Supercharged
Post #708167 3rd Jan 2025 11:02am
Epson Green
Passed MOT - no advisories😁
Paid 12 months road tax☹️ Kevin
2012 L322 Westminster 4.4 TDV8
1999 P38A 4.0 SE - Sold
Post #708189 3rd Jan 2025 2:37pm
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Took some pics of it on the snow!
 12 4.4 TDV8 Vogue
Nara Bronze / Arabica / Ivory / Piano
07 3.6 TDV8 Vogue
Buckingham Blue / Sand / Piano
Post #708404 5th Jan 2025 9:30pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Lovely pictures @Sql 👏🏻👏🏻
Today I got the rear wiper wash functional. It was wiping but didn’t wash. It’s been about a year so it was well over due! It was blocked nozzles, so a cheap and simple fix.
Ordered all the parts for a major service.
Ordered all the parts to rebuild both rear callipers, pistons etc.
Sat and looked at her for a while, god I love the L322! 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #708405 5th Jan 2025 9:37pm
RangeAnxiety
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
It was the Scramble at Bicester Heritage today. I’d got a display ticket for my 106 Rallye but the conditions were too crap to bring that out. So the L322 ended up on display. It wasn’t the only one. And it seemed to get more attention than I thought!
Well worth a visit. Next one is in April - I think tickets go on sale tomorrow.
 2011 L322 4.4 TDV8 Vogue
1999 Mercedes R129 SL
1995 Peugeot 106 Rallye
Post #708418 6th Jan 2025 12:30am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Spent 4 hours, lot's of cursing and hammering with ever increasing sizes of mallet to remove the HD variable height hitch assembly off the car now that I'm not towing so much.
Not weighed it, but has got to be 30kgs of steel there, this has had added box section welded in to prevent sagging by the looks of it, I had to cut that off because whomever fitted it actually welded the angle piece to the lower flange of the towbar frame, thus rendering it unremoveable..
Eventually after an hour using my reciprocatinf saw and using blowtorch, 5lb mallet, loads of WD40 and a long prize bar with the whole lot under a lot of tension of a mini bottle jack horizontally, finally got it out.
Have now resurfaced the square tubing passthrough, greased and put it back to standard hitch now so I have it when I need it but car looks better without it.
Don't know who did that, but must have been a reason for it and was done a while ago judging by the corrosion.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #708454 6th Jan 2025 3:17pm
Bazzasglovers
United Kingdom 2009 Range Rover Vogue SE TDV8 Alaska White
Nice easy swap out of the Start/Stop switch,as per previous posts only a 5 minute job👍👍
Post #708669 8th Jan 2025 8:45pm
hmallett
What have I done today? Nothing, except put the battery charger on it.
This is because I went to start the engine. At ignition on, I immediately got the message that the infotainment would turn off in 3 minutes. Then when I pressed the start button, there was nothing but a click. Sad
The primary battery is only 18 months old. I don't know the age of the auxiliary battery (will have to remove it to see the label). Car has been sat for a week, and it was -7 degrees overnight. I knew these cars have a reputation for chewing through the battery, and have had the low battery message before, but this is the first time I've had a car with a battery flat like this in about 15 years!
Post #708742 9th Jan 2025 9:39pm
AndyRoo
Sat in the dining room with a nice mug of tea earlier this morning just as the day's dawning marvelling at all the muggles in my street scraping and cursing on one of the years coldest mornings as I watched my Rory defrosting his-self on the timed climate I'd set for 07:50.
Knowing that in 5 minutes time I'd have to brave the freezing cold myself in the 3 metre dash to the car through the cold before setting off on the school run.
It's the small things of FFRR ownership that make it all worth while Whistle
Sad shame of it is, I'll repeat the exact same thing tomorrow morning. Rolling with laughter Rolling with laughter Rolling with laughter
Post #708796 10th Jan 2025 1:54pm
