Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 38 of 38 <123 ... 363738
Andrew millar
United Kingdom 2013 Range Rover Autobiography SDV8 Fuji White
Hi I have the same problem did you find the cause of the leak
Post #705334 24th Nov 2024 3:17pm
s1tommy
Garymcduff1 did you find the spray leak in the end on this as I have an issue exactly the same and cannot find the source? Cheers Tom
Garymcduff1 wrote:
Hi all, came across this forum whilst trying to research/locate an oil leak on my 2013 4.4 sdv8.i had the oil cooler gasket replaced back in December 2021 and all was well until about 6 months when an oil leak was noticed on a service. I got what seams to be an intermittent oil leak towards the front of the engine somewhere between the throttle body and drivers side valve cover, it can go days with no leak, then a slight leak and then lots dripping from everywhere under the drivers side of the engine, when it leaks it's also spray oil up onto the engine cover (lots of oil it's soaked) and the bonnet when cover removed. I've check all inlet pipes, egr, valve cover and anything else that can be tightened and tried looking for it whilst putting the car through different rev ranges but can't locate it. Not sure if it's related but when driving if I drive hard enough for the secondary turbo to kick in it blows a puff of blue smoke, but once the smoke has cleared i can continue to drive hard and no smoke. I don't think the oil leak is a turbo seal as the amount it's losing I'm sure the tailpipes would be constantly pumping out blue smoke so wondering if anyone has experienced this and have any ideas what's going on as I'm completely stumped now.
Post #706111 4th Dec 2024 9:26pm
s1tommy
@Garymcduff1 did you find anything from what i mention above? any help appreciated.
Post #706238 6th Dec 2024 12:18pm
Just as an update you can now buy LR orings as a part for the leaky Union.
lR part no is LR124504
Not sure if this has been posted or not but can be bothered to sift 38 pages to find out…… There is nothing that can't be fixed with a hammer😜😜
Post #707949 31st Dec 2024 6:00pm
GraemeS
Australia
At the price, I wonder who would buy one let alone 2!
Post #707981 1st Jan 2025 12:55am
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
But Graeme, you are forgetting it’s a GENUINE O Ring - worth its weight in gold 😂😂😂😂
Post #707990 1st Jan 2025 8:56am
Advanced factors do them at a few quid with that part number 👍🏻
https://www.advancedfactors.co.uk/lr124504-oil-seal There is nothing that can't be fixed with a hammer😜😜
Post #708083 2nd Jan 2025 11:52am
toby1
LR wants £24.01 each so it can politely FRO. 2012 Vogue TDV8 in Aintree green over sand
Post #708085 2nd Jan 2025 11:59am
PeteT80
Less than £5 for 10 on a certain auction site. Viton BS611 - 8.73mm ID x 1.78mm C/S
Post #708255 4th Jan 2025 2:08pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
I have some oil and definitely some coolant under this hose. It is the hose on the right rear side of the plenum.
I am not sure if there is an o-ring I could replace or I need to change the whole hose.
Can anyone help? what size is the o-ring? or any part number for the hose?
Cheers
Fatih 2011 Vogue SE 4.4 TDV8
Post #713906 12th Mar 2025 7:00pm
