![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Andrew millar Member Since: 25 Sep 2024 Location: Northern Ireland Posts: 1 ![]() ![]() ![]() |
Hi I have the same problem did you find the cause of the leak |
s1tommy Member Since: 20 Mar 2024 Location: Coventry Posts: 4 ![]() ![]() |
@Garymcduff1 did you find anything from what i mention above? any help appreciated. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Just as an update you can now buy LR orings as a part for the leaky Union.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2637 ![]() ![]() |
At the price, I wonder who would buy one let alone 2! |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 50 ![]() ![]() ![]() |
But Graeme, you are forgetting it’s a GENUINE O Ring - worth its weight in gold 😂😂😂😂 |
Advanced factors do them at a few quid with that part number 👍🏻
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 223 ![]() ![]() |
LR wants £24.01 each so it can politely FRO. 2012 Vogue TDV8 in Aintree green over sand |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 221 ![]() ![]() ![]() |
Less than £5 for 10 on a certain auction site. Viton BS611 - 8.73mm ID x 1.78mm C/S |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 69 ![]() ![]() ![]() |
I have some oil and definitely some coolant under this hose. It is the hose on the right rear side of the plenum.
