Home > My Range Rover > 5 RRs and I have to give up |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 669 |
Thanks David,
30th Nov 2024 9:32am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
in my opinion, if air is getting in, which i doubt, there must be a restriction between the reservoir and the pump.
30th Nov 2024 12:16pm |
Great thoughts Knares,
30th Nov 2024 1:04pm |
Well, it's been consistently... awful today.
30th Nov 2024 9:12pm |
More late night messing,
30th Nov 2024 11:01pm |
Can someone with suitable diagnostics and a 2006-2009 pre LCD dash L322 please check this out for me?
1st Dec 2024 11:44pm |
So for anyone still reading, I've just done the test where I feed 12v direct to the servotronic valve bypassing the BCM output.
3rd Dec 2024 9:23pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1191 |
Yes we are still reading, thinking back to when Haylands drove your car, a thought struck me. I have only ever driven my 2006 td6 and my 2007 Tdv8 3.6, and will admit there are days when I think the suspension has become a little 'crashy' and response seems to have been 'dulled down' then the next day I climb in and the car(s) seems sublime in handling and response.
5th Dec 2024 8:58am |
My original RR was great during its first year with me, it always drove great and felt consistent.
5th Dec 2024 10:00am |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 68 |
I don’t know if this information is useful but someone with a current generation Mini had all sorts of driveability issues including intermittent strange steering and the fault was cured after fitting a new outside temperature sensor . There are of course many sensors can cause issues . |
5th Dec 2024 10:06am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
Maybe time to go back to Bentley? Got - 2017 SDV8 Autobiography in Loire Blue
5th Dec 2024 10:37am |
@MarianaW I have an IcarSoft tool... BUT... it is currently on loan to a friend, will try to get it back and have a look at the values before I go back to sea |
5th Dec 2024 11:45am |
That would be very helpful and most appreciated Merchy, thank you.
5th Dec 2024 9:31pm |
The temp sensor is probably ok if it shows the correct temperature |
5th Dec 2024 11:56pm |
