Home > My Range Rover > 2012 Vogue TDV8 |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 121 |
Refreshed and now over the post-holiday blues, another look at this leak. It is not coming from the hose I suspected, but I am fairly sure it is from the right hose where it goes into thermostat housing. There is no seal listed so I guess it is part of the hose and this is only serviced as the assembly.
3rd Nov 2024 1:57pm |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 331 |
Try a search, the hose may have an o ring that can be replaced. |
3rd Nov 2024 2:23pm |
And sure enough, the forum weighs in: https://www.fullfatrr.com/forum/topic66813...+hose+seal 2012 Vogue TDV8 in Aintree green |
3rd Nov 2024 3:17pm |
The O rings duly arrived and fitted to both large hoses. I decided against changing the little one as it wasn't leaking but I have a pack of 5 in case.
10th Nov 2024 3:48pm |
I have just checked and the coolant level is stable at where I left it yesterday but it is a touch below the mark. I have checked all the vacuum lines are all in place. I could adjust the 4 x intake hoses to see if I have a leak there.
11th Nov 2024 12:42pm |
This lunchtime I have undone the doughut hoses and centralised them in case I had a leak. Hopefully that rules those out.
15th Nov 2024 1:46pm |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 52 |
toby1
16th Nov 2024 2:04pm |
It was certainly worth trying. I have unclicked and reclicked the air sensors on the air filters and the one on the doughnut to no avail. I did clean the doughnut one with brake cleaner - hopefully that hasn't broken it.
17th Nov 2024 12:38pm |
Have I stumbled across my issue whilst reviewing my snaps? I realised that I had not replaced the broken connector still in my tool box in the boot. I was too hamfisted with it and it broken away from whatever to which it was connected. Numpty.
It is the fuel pressure sensor on the LH rail which no doubt would not help proceeedings if not plugged in. I managed to connect the harness to the broken plug but I cannot connect this to the sensor. Happily, both sensor and harness are listed separately. The sensor appears fairly generic at around £40 (LR020693) but there are no harnesses (LR042445 supersedes to LR112662) on eBay at sensible money. Thus, I will research how to change this sensor. 2012 Vogue TDV8 in Aintree green |
20th Nov 2024 1:33pm |
I think I have found how to release the fuel pressure, according to the manual:
20th Nov 2024 5:50pm |
I have the sensor now but I am wary about de-pressuring the rail. Is it as simple as undoing the sensor? Hmm.
21st Nov 2024 11:12am |
I found the procedure in the end. The file name was spelled incorrectly.
21st Nov 2024 12:47pm |
