![]() | Home > In Car Electronics (L322) > 2012 Audio quality |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
One of the "bass" speakers in my door was bust, so I swapped that for a Focal.
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 88 ![]() ![]() ![]() |
Thanks, yes my understanding of Logic 7 is essentially turning surround sound on, I would guess (but haven't tested) that the rear pillar speakers would only be used for the Logic 7 as well, like the center.
I'm not sure what the mid-range speakers are in the fronts, they look to be smaller than 10cm, possibly even tweeters put into a 10cm sized housing?
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 124 ![]() ![]() |
I was thinking about this today. My challenge with the audio quality is that the bass amplification seems to be non-linear with volume. At lower volumes, the sub is lacking or you have to max out the settings to get good response. Then you turn the volume up and the bass levels increase, resulting in a bass overload, if such a thing exists. My original plan was to try and stick with teh original sub but add an inline amp to tweak the volume levels but I suspect this will simply provide a better bass level at regular volumes then an overload when louder. To put it another way, I'd like to change the equalisation levels at different volumes to get a more linear/consistent bass level. |
Not in car, but my home TV amp has a dynamic EQ, which will change the EQ as the volume increases, I think it's maybe the human ears which are non linear and don't perceive bass as much as lower volumes.
Makes total sense and I've been thinking the same with my other car (where I listen to music more). What I'd like is for DSP's to have an option where you can adjust a level based on the overal volume. This is basically, AFAIU, why radios have a "Loudness" option, so give extra mid-range and bass when the volume is lower. My head unit on my other car does have a Loudness option and also an equaliser which can be used to overcome this, but I'd love it to be non-linear and adjustable in the DSP settings, ideally. As it is, I EQ'd the car based on a normal listening volume of about 75dB or so. That particular car I tend to drive myself (weekend car), so it's not so critical - but for the Rangie I usually have a passenger, so I'd really like to get more bass at a lower level of volume so I can have a conversation but still have good music. Most decent amp's (especially bass orientated single channel) tend to come with a remote adjustment knob so you can do this btw. The 8 channel amp I have in the other car has an adjuster specifically for the 2 bass channels which just affect the amplification of those channels, which would work - though I hate aftermarket knobs and switches in the car, as a rule ![]() |
Bass needs a lot more watts to achieve the same perceived volume, yes, exactly. You're moving a bigger physical speaker and an associated larger amount of air to create the noise, so it's logical it requires more current to get you there! The whole usage of a DSP in cars is still relatively new (as in, our 2011 RR's were quite advanced by having a DSP in them, even if it was incredibly basic and not configurable). My other car is a 2002 and had a "DSP" as standard, but it's factory tuned by Bose and not configurable - in those days they mostly used a DSP as a way of overcoming lacklustre (read: cheap) components and improve the sound quality for less cost. The aftermarket DSP I added was also pretty cheap (150 usd or so), but gave me full control over all 8 channels and allowed me to set EQ and time delay across each. For home hifi I've played around with CamillaDSP, which is a whole other step forward in terms of what you can do with EQ, volumed related EQ, convolution filters etc - but there's nothing quite that advanced in the world of car audio, AFAIK.
Actually the head unit isn't where this is usually done, they tend to provide just 4 channels of sound, Front-left, front-right, rear-left and rear-right. Many aftermarket setups only use 2 channels (as most audio recordings are still only 2 channel). But a Front to Rear fader is common. The head unit in the L322 (2011/2012) provides 5.1 channels via optic (MOST) to (what I understand is) a combined DSP+Amp. The 5.1 channels will only be populated when playing a DVD, Audio from the CD player, radio or Aux-In is going to be 2 channel still. The DSP is going to be pre-configured in terms of time delay per channel, but has the configuration from the head unit for Sub channel, Bass and Treble. The cheapest/easiest option to add a full DSP function, looks to be the Mobridge combined DSP+Amp solution which can accept the 5.1 channel MOST as an input. You would lose the head unit control of the Sub/Bass/Mid (no great loss), but at least retain an OEM look and the access to the cameras, clock setting, suspension info etc. The Mobridge DSP doesn't look to be able to do dynamic EQ, but can EQ per each channel, set crossovers more accurately, fix time alignment etc. |
Ah so you can bypass the existing amp in preference for an aftermarket with more power and configurable EQ ? Quite pricey units from Mobridge
Well, it's 1200watts, but at 4ohms rather than 2ohm.
