![]() | Home > In Car Electronics (L322) > 2012 Audio quality |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
The audio is not as good on this newly acquired vehicle as I was expecting. The 2007 TDV8 Vogue SE was outstanding and I had to turn down base and subwoofer. This is 'tinny'. I have bass up to max. The subwoofer control seems to make no difference. That is also up to max.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
Which system do you have? 750W or 1200W (speakers labelled Logic 7 HD). |
Premium ICE 1200W 2012 5.0L S/C
Tried everything. CD, Radio, DAB. Running and engine off. Very poor sound. Tinny as if there is no sub-woofer or any base at all. Ok for listening to the news but no good at all for music. Discovered this in a 6 hour drive to Yorkshire.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Try to see if the sub is actually working at all, play some music then open up the left have boot compartment, the sub is the black plastic thing blocking the front of the compartment. See if you can feel any resonance in the chamber or feel the driver moving at all, if the amp was out I suspect you would get nothing at all,'but it could just be one section driving the sub which has failed.
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
I think you may well have an issue with yours? I can make my ears bleed and innards rumble with my Logic 7 system. AC/DC are a particular favourite! |
Thanks guys. I thought as much. I'll check the sub-woofer tomorrow - I'm in Yorskshire so obviously it's raining at the moment |
Take the cover off the left inside the boot and you can see the subwoofer. Check its not become de-laminated! They often do |
Thanks Craig. Stupid question but what does 'de-laminated' look like? Is it obvious?
Big oval speaker that is no longer glued together |
Sub woofer is working but no oomph! With high volume and full base and no treble with full sub woofer it begins to sound OK but not earth shattering like in my old one.. Turn down the volume a small amount and it gets tinny. Could be more of an amp problem? 2012 5.0L S/C
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
Any news on this?
Took mine in to the dealer for them to take a look. They said they did a software upgrade. No significant difference. Only sounds powerful at very high volume. Nowhere near as good as the old system in my 2007 tdv8 vogue se. Dealer days that there is nothing wrong with it! I now have sub woofer and base to near max and treble to near min. Barely acceptable sound but not good. 2012 5.0L S/C
Same Same.... again dissapointing (same dissapointment than with the missing infolevel in the main TFT)
