![]() | Home > In Car Electronics (L322) > 2012 Audio quality |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Watched Sam's Motor & Machine the other day and got me wondering as my subwoofer, although working is really dull at low volumes and not that great at high volume either on MY 2012 Logic 7 HD system and I was considering replacing with a bass box, but would prefer to retain the boot space.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
Try turning Logic 7 off.
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Totally agree, Logic 7 is awful. Drives:
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
I’m also with you about the sound quality of the HD system. As you say, when you turn it up it’s great but a lower volumes there is almost a tinny sound.
Hi, the main door speakers are 16.5 cm 2ohms, does anyone know what the midrange units in the doors are and the ones in the rear pillars ?
th3chainrule Member Since: 24 Sep 2022 Location: East Posts: 16 ![]() ![]() |
All of the speakers are 2 ohm. You'll want to find a decent 3" midrange for the f&r doors, center, and pillars. I went with a 2 ohm 3 way kit from CDT Audio to replace mine which included 6.5in, 3in, and a tweeter.
Has anyone tried replacing the HD door speakers?
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 33 ![]() ![]() ![]() |
Hello folks, I also had the same issue with the poor HK logis 7 standard system and I’ve replaced my stocks speakers to Focal, Audison and Hert speakers combo, plus deadened the doors. The sound quality has improved somewhat, but I would say it could still improve further.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
Link to the tutorial/writeup on replacing the door bass speakers with Focals: https://www.fullfatrr.com/forum/topic57819.html
Hey, Did you also do the Mobridge amp swap and if so, how is it? ![]() |
This is how the Logic7 looks with the addition of the Focal ES165K2 in the door speakers.
This is good info thanks, nevertheless an aftermarket amp which gives you full setting and adjustment options could help this picture i guess. For me both the bass and high have become better with the focals, but still the sound is not what I call good… |
Totally agreed - hence my interest in the mobridge!
