Home > Technical (L322) > L322 4.4 TDV8 putting out clouds of white smoke at idle.
Page 3 of 3 <123
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Could the high pressure pump timing be out? That wouldn't I don't think generate a fault code or would it?
That might explain the white smoke and I'll throw in the PCV valve to explain the pressure drop in the fuel rail.
However I would not expect the smooth idling. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #703152 27th Oct 2024 2:26am
GraemeS
Australia
I doubt that a fault would be detected and if the timing was retarded then I would expect idling to be very smooth.
How difficult is it to check the HPFP timing?
Edit:You would need the tool to set the crankshaft in the correct pump timing spot (presumably TDC) and the tool to set the pump position that locks the gear at the correct angle.
The woodruff key would be facing one way or the other depending on whether or not #1 piston was on its compression stroke.
Post #703153 27th Oct 2024 2:56am
JayGee
The exhaust gas temp is still high enough even on cold start to vaporise excess oil or diesel in the exhaust. White smoke on startup is a classic sign of exhaust side turbo seal failure and it would still run smoothly. 2012 TDV8 Vogue (L322)
Post #703155 27th Oct 2024 8:52am
dhallworth
I had a look under the bonnet of our 4.4 as I was in the workshop next to it earlier.
I wonder if you could remove the intake pipe from the throttle body and start the Range Rover? That way you've removed all of the turbo pipework from the equation and the car is running on fresh air being sucked in at the top?
If it would run for a few minutes like that so you could clear out the exhaust you should in theory be able to tell very easily if it was the turbo causing the car to smoke.
Post #703217 27th Oct 2024 7:49pm
RobErica
Netherlands
That white smoke kan be caused by the turbo leaking on the exhaust side. It then just heats the oil instead of burning it. Uou wont find much oil in the intercooler.
Cant explain the rise in oil level though. Maybe somebody was a little enthkousiastic when filling.
Post #703222 27th Oct 2024 8:45pm
Dijit
I accept what you say but not in the first two seconds of starting from stone cold surely? The video last 23 seconds. Granted I revved it when the smoke became a white out but at idle within 2 seconds or less of starting? Sorry I can't see that. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #703223 27th Oct 2024 9:10pm
JayGee
I think a leaking exhaust side turbo oil seal will smoke almost immediately on cold start. As long as there are hot combustion gasses entering the turbo exhaust side and there is oil in there it will vaporise. 2012 TDV8 Vogue (L322)
Post #703229 27th Oct 2024 10:17pm
JayGee
David.
It’s not blue smoke so you can effectively rule out an intake oil problem. Turbo’s can leak from the compressor side but usually it’s the exhaust side as this is where the combination of heat and oil lubrication problems will do the most damage. 2012 TDV8 Vogue (L322)
Post #703231 27th Oct 2024 10:24pm
Dijit
JayGee How can you test for that?
Post #703236 27th Oct 2024 10:48pm
Dijit
JayGee How can you test for that? Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #703237 27th Oct 2024 10:49pm
JayGee
Test for a leaking exhaust side turbo oil seal? 2012 TDV8 Vogue (L322)
Post #703238 27th Oct 2024 10:54pm
Dijit
JayGee Yes, test for a leaking turbo oil seal. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #703242 27th Oct 2024 11:33pm
JayGee
White smoke that smells of engine oil is the obvious one. Collect enough of it in a rag over the tailpipe and it should be easy to tell if it’s oil or diesel. Unbolt the down pipe from the turbo and an oil leak will be obvious as will any excessive turbo shaft play. Main reason for turbo oil seal fail is oil starvation. 2012 TDV8 Vogue (L322)
Post #703244 27th Oct 2024 11:42pm
Dijit
Thanks JayGee. Anything else that can be checked? Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #703247 27th Oct 2024 11:51pm
JayGee
Actualy you may not even have to unbolt the downpipe as if it's leaking oil it will likley be seeping out of the joint between turbo and downpipe. 2012 TDV8 Vogue (L322)
Post #703256 28th Oct 2024 8:18am
Page 3 of 3 <123
